worn clutch?
Old Sep 24, 2009 | 11:08 PM
jdm_rsx's Avatar
Default worn clutch?
well...first of all i duno if im posting in the right section...
if so im sorry...maybe ya'll can pinpoint me where to go....
2nd of all...what are some signs of a worn clutch?
i noticed that my clutch....before...i had pressure all the way....from the top
lately, i notice that...i had to step on the clutch i'd say a little more than half way before it engages.. clutch worn or just readjust..or something else?
its late now but i plan to check clutch / tranny fluid tomrorow...to see if i need more...
feedback?
Old Sep 25, 2009 | 06:25 AM
heathas2k's Avatar
If you're clutch is slipping it's worn and on it's way out. *you floor it and the rpms shoot up before it grabs* You should also be able to smell your clutch burning up. This is the best indication.
In your situation I'd check the master cylinder for leaks, as well as check out the slave cylinder. Bleeding the clutch may help the situation, but if you have leaks then you might have to fix/replace cylinders.
Old Sep 27, 2009 | 08:16 AM
p-p-porkchop's Avatar
check your fluid
Old Sep 27, 2009 | 07:48 PM
Tech7427's Avatar
put that bitch in 5th and hit the gas hard going up a hill, if it doesnt slip the clutch is more than likely fine. from your description (slightly confusing) sounds like a hydrolic issue
Old Sep 27, 2009 | 07:58 PM
common reactor's Avatar
Originally Posted by p-p-porkchop,Sep 27 2009, 08:16 AM
check your fluid
I'd probably agree with this post. Although that might not be your problem...unfortunately through written explanations one can only help so much.
regray1
Apr 10, 2017 08:40 PM
Jag528
Dec 4, 2012 08:13 AM
Dragon Slayer
Dec 7, 2007 05:56 AM
firefighter770
Nov 25, 2007 02:53 PM
DiamondDave2005
Jul 28, 2005 11:01 AM
