Would this work for pre-loading the suspension?
Old Jan 29, 2006 | 11:16 PM
Kschmied's Avatar
Default Would this work for pre-loading the suspension?
When I get in my eibach springs, heres the plan I have. I'll install the springs like normal, and just barley tighten the a-arm and strut mount bolts. Then, jack up the front of the car, and lower the wheels down on to some 12" ramps I have that are too steep to "drive" on to... crwal under and tighten... jack it up, and remove ramps / lower. and practically do the same for the rear. One thing I was curious about, and forgive me if this is a dumb question ( my first full RWD car ), but can I jack up the rear of the car, with the front's on the ground, or would I have to use a stop for the front wheels?
Any input would be appreciated.
Old Jan 30, 2006 | 04:49 AM
Somehondaguy's Avatar
As a reminder here, the emergency brake works on the BACK wheels only.
Also when you put your RWD in gear, that will stop the BACK wheels only.
What I'm trying to say here is NOTHING stops the front wheels while the back is jacked up. Hint Hint.
Old Jan 30, 2006 | 08:18 AM
3ngin33r1's Avatar
NEVER jack up either end of the vehicle without the opposite end wheels blocked. DO NOT rely on the e/p-brake or gears to hold the vehicle while you crawl around under it.
It's not worth your life. Chocks are cheap.
Old Jan 30, 2006 | 10:15 PM
4bang6's Avatar
Old Jan 30, 2006 | 10:45 PM
mikegarrison's Avatar
That's really good advice.
That being said, I jack up the rear all the time using the diff, and just trust friction to keep my floor jack from moving. It never has so far. I would never go under the car without jackstands, though.
Old Jan 31, 2006 | 11:39 AM
Kschmied's Avatar
Okay, so I'll chock the front wheels, and get some extras so I can be sure to chock ALL wheels on the ground in the future, but no one's commented on my plan for pre-loading the suspension yet :/
Old Jan 31, 2006 | 02:52 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Correct. The suspension should be compressed before tightening the upper a-arm bolts (especially), and the lower shock bolt (not critical, as there is minimal rotation of the bushing when the car is lowered onto the suspension).
Old Jan 31, 2006 | 03:48 PM
Kschmied's Avatar
so i technically only have to pre-load the fronts?
datbino
Jun 24, 2013 01:16 PM
s2image
Aug 29, 2009 06:11 PM
kem_kc
Feb 2, 2009 11:47 PM
spaceman_spiff
Oct 12, 2007 12:05 AM
Crispy Rice
Jun 1, 2007 10:52 PM
