WTF happened!
WTF happened!
Happened on Monday, car dash lights just started flickering on highway..I shut off and pulled over to check fluids/battery line and everything was fine. I turned the car on and my a/c wouldn't blow cold. I didn't think anything of it but then when I downshifted to jump into the traffic, car shitted on me and it didn't pass 6k. NO CEL has come up.
Thought I blew something so I checked it out again. No rattles, no knocks..just wont pass 6k.
Checked my grounds. Checked my fuses, at least the ones I thought I should check. Just did an oil change 2 days before everything started happening.
Can someone pleeeease give me some sort of direction. I will paypal you 20$ for advice lol Times are rough and I need my car to get to my job.
It wont hit vtec. A/C blows hot.
Help!
Help!
Thanks all but none of the above works
checked oil. normal.
checked coolant. normal.
Took battery out to adjust negative cable ground , again, nothing changes.
Also, while driving car does not read speed correctly. I will be driving at 70mph and it will mark 35-50. The a.c goes blows colds every couple of minutes or so but then goes dead.
SLracer - the car does feel drive like it would if it was cold, however I get three bars? confused.
I have a feeling its electrical but I havent the slightest clue where to start.
