Yellow Box Installed=Check Engine Light??
Old Jun 9, 2003 | 10:56 AM
  #41
Station's Avatar
Drill a tiny hole and put a grommet in it. That's the easiest way.
Old Jun 9, 2003 | 11:06 AM
  #42
rateds2k's Avatar
That is what I thought. How about the power and ground leads? Any ideas?
Old Jun 9, 2003 | 03:47 PM
  #43
xviper's Avatar
[QUOTE]Originally posted by rateds2k
[B]
Old Jun 10, 2003 | 05:14 AM
  #44
rateds2k's Avatar
[QUOTE]Originally posted by xviper
[B]
Any "switched" hot wire will do.
Old Jun 10, 2003 | 06:25 AM
  #45
Sideways's Avatar
Don't use the one that is switched with the parking brake. The speedo would only work with the brake on.
IMHO, you should reconsider what you are doing.
It really is SIMPLE (excuse me) to do it like the color picture Modfry posted earlier in this thread. It takes about 5-10 minutes to install. Clean and simple and available to adjust and all. There is a neat channel in the body running along the bottom of the kick panel. After you have the Yellow Box adjusted you can just drop it in there out of the way behind the panel. Too easy?
Old Jun 10, 2003 | 06:32 AM
  #46
rateds2k's Avatar
But from what I have been reading the cel could come on if I do it that way.
Old Jun 10, 2003 | 06:52 AM
  #47
Sideways's Avatar
No way. Use the wires Modfry pointed out and you are home free. Mine works fine.
FYI, I needed to change the YB 12% to get the speedo exactly on with worn SO2s on 1/2 inch wider wheels.
Old Jun 10, 2003 | 06:58 AM
  #48
Sideways's Avatar
Here, I cut through some of the extra stuff:
[QUOTE]Originally posted by modifry
[B]The blue/white speed signal wire leaves the speed sensor on the tranny and runs through connector C101 (behind driver's foot well, closest to the dead pedal) and then SOMEWHERE (over the rainbow??) it splices with another blue/white wire that goes to the ECM.
Old Jun 10, 2003 | 07:20 AM
  #49
rateds2k's Avatar
Thank you.
Old Jun 11, 2003 | 01:57 PM
  #50
fltsfshr's Avatar
I ran my yellow box off the tranny like xviper showed except I tapped the hot lead in the console for the flasher. I was getting a CEL showing up randomly. It turned out to be an insecure connection in the plug supplied by yellow box...I gave up trying to set my yellow box by mile marker..they aren't accurate..so I took my chart plotter from my boat at set it via gps ...the setting turned out to be either an 8 percent or a 7.75 percent correction not a 10... I've had no problems since I made sure the wire connections on the plug were good...
fltsfshr
