YELLOW BOX problems!
Old Jun 26, 2006 | 09:38 AM
C4SxM5's Avatar
Default YELLOW BOX problems!
I installed my yellow box last night everything seemed to be working correctly eventhough I did not get the chance to mess with the switches.
This morning while driving however I noticed several issues that weren't there before.
1. NO MPH
2. GAS gauge would move up and down similiar to the RPM Gauge
3. Odometer mileage wasn't moving
I pulled the car over at that point and unplugged the YB, reconnected the BLUE/WHITE wires and everything came back to normal...
Can someone look at my wiring and confirm that I got it right. If so, why is it acting up???
Not sure if this may make the difference, but I'm also running EMS and got the install instructions from here:
https://www.s2ki.com/forums/index.ph...&f=22&t=119078
4th BLUE/WHITE wire connected to GREY wire
4th BLUE/WHITE wire coming from the clip connected to the WHITE wire
RED YB wire tapped into the Yellow wire w/ Grey Dashes (NO Black Stripes)
BLACK YB Wire grounded
Old Jun 26, 2006 | 09:59 AM
Stratocaster's Avatar
The Yellow box has built-in diags. In it on the instructions that shipped with it. But the short version is that either bad power connections (either one) of bad connections from the speedo wire will generate this issue. Pull the Yellow box out of the car, and install the small jumper connector that shipped with the YB. If you still have the issue, then it is surely your connections.
Old Jun 26, 2006 | 10:04 AM
The Yellow Box harness has four wires;
Old Jun 26, 2006 | 10:07 AM
s2kmaniac81's Avatar
figure out how to fix everything except the odometer and you will be sittin pretty!
Old Jun 26, 2006 | 10:27 AM
Yeah, but they are all tied together. Can't make one work without the others.
Old Jun 26, 2006 | 10:49 AM
C4SxM5's Avatar
Stratocaster:
"install the small jumper connector that shipped with the YB"
I still have the jumper connector, but have no clue on how to connect that part. I'm thinking its my power wire because that's the only wire that I didn't solder together, so will try that.
The green wire has been switched to Grey I think because I don't have a Green wire at all and others in the YB Install thread also have Grey wires now.
Old Jun 26, 2006 | 11:08 AM
It only fits one way, the right way.
Old Jun 26, 2006 | 11:09 AM
Also there is a factory ground location up a bit higher. Ground it to that location instead as well.
Old Jun 26, 2006 | 01:01 PM
C4SxM5's Avatar
re-did the power wire and everything is back to normal!
thanks
vstypicals
Sep 26, 2013 10:08 AM
Pastor
May 30, 2009 11:12 AM
pemex70
Nov 9, 2007 11:56 AM
batikan
Jul 27, 2006 05:17 AM
04RioS2k
Dec 26, 2005 08:11 AM
