YELLOW BOX - wiring How To
#22
Very informative thread. I purchased a Y/Box a month ago and have yet to install it, but I think I'll go with the cabin splice.
I recently had 4.44 gears installed this past Friday so I'm definitely off on my speedo. In the box the gears came in, from Motorklasse, there was a notice mentioning I would be off -8.3 percent.
#24
I was thinking of getting some 4.44 gears also. This is good to know for the yellow box calibration. Anyone know what the correction should look like on the yellow box. I am the worst at numbers...
#26
so the attempt to install my yellow box has been a failure. i am not sure which part i am not wiring up right. its grounded, i get a led signal, so i am assuming my power is connected correctly. i have tried to follow in the instructions on here, but my speedomter still reads zero. i have tried splicing into the blue/white wires at multiple places, any suggestions would help. i have a 2006, and its been hard to follow because seems most if not all instructions are for ap1. thank you.
#27
Id like to know as well. Ive spliced it at diff areas as well, including at the speed sensor, but no luck yet.
#28
I tried to install a Yellow Box on my MY07 with disappointing results. I followed the supposed instructions for the 06+ DBW cars, that require a more complex splice into harness. The VSA, cruise control, speedo, worked at first -- with an exact MPH display, and then I kept getting a check engine light. Then the speedometer stopped working altogether, and the VSA light flashed intermittently. Eventually the car would lose all power and stall. It was a disaster, so I removed all traces of the damned thing. I still have trouble sometimes that relate to the attempted install. I think it is a bad idea to mess around with a DBW harness and ECU. They are very different from the AP1s and also very sensitive to invasive spicing.
Anybody with an AP1 or a pre-DBW Ap2 interested in a pristine Yellow Box? j/k
#30
i am trying to install a yellow box right now on my00 and I am having trouble getting power to the box. Where did you guys tap in at for power. my box is not lighting up at all. i hooked it up under the left kick panel the way gary posted on the previous page
