Yellow Jacket speedo problem
Old May 6, 2008 | 04:53 PM
S2Kinside's Avatar
Default Yellow Jacket speedo problem
Ok, so here's the deal. I've had my Yellow jacket speedo calibrator installed for the past 2 years without issue, but ever since I installed my comptech charger, the speedo has been acting strange. Here's what it does.
Under hard acceleration, sometimes the speedo will go to 0 MPH all of a sudden. It will stay at Zero untill you pull the plug on the yellow jacket and re-plug it in. This never ever happened before the charger install. Has any one had an issue with the car accelerating too fast for the module to compensate? I know that sounds crazy, but I can't figure out why it would have worked fine for 2 years prior, but now as soon as I install the charger, it starts messing up. Anyone have a high HP S2000 with the Yellow Jacket installed?
Here's some background on my car. The car is a Miata with MY02 F20 installed. The rear end is a Miata Torsen LSD with 4:10 gears. The rims are 14s so thats why I need the Yellow jacket module. The smaller tires (smaller then the S2000s) Changes the final drive ratio.
Any experience would be helpfull. Thanks Guys!
Nils-
Old May 6, 2008 | 05:01 PM
Slows2k's Avatar
Run a separate ground to the yellow jacket.
Old May 6, 2008 | 05:18 PM
S2KPUDDYDAD's Avatar
A stronger ground is needed, after about the same amount time with my YJ I had an issue with it too.
Old May 6, 2008 | 06:12 PM
S2Kinside's Avatar
I'll give that a try. Thanks for the advice!
Old May 6, 2008 | 06:45 PM
TheCarGuy2021's Avatar
I had the exact same problem when I used to be geared and supercharged.
Old May 7, 2008 | 09:00 AM
S2Kinside's Avatar
Did you end up fixing it? Or just put up with it until you took the charger off?
Old May 7, 2008 | 10:09 AM
I just put up with it. I mounted the calibrator on my gauge pillar and simply unplugged it and plugged it back in whenever I had a problem.
Old Jul 24, 2008 | 10:44 AM
neeman77's Avatar
Sorry to bring this back from the dead but I am also having this issue. I was wondering if you folks switched to non-resistor spark plugs (NGK 7173) because I have a hunch that these are what are causing the grounding issue. I had my yellow jacket in for some time with no issues until around the time that I installed the spark plugs. I will check it out tonight as we could have a discovery on our hands haha.
Old Jul 24, 2008 | 03:28 PM
s2k aok's Avatar
nice find if it proves to be correct...
Old Jul 25, 2008 | 08:56 AM
negcamber's Avatar
No...I have the problem and still have OEM plugs.
