Yellow Jacket speedo problem
Old Jul 25, 2008 | 02:22 PM
neeman77's Avatar
hmm fair enough...what about the air pump do you still have that? If the spark plugs are not the issue it may have to do with the electronic load detection. Im just trying to figure out what is happening here.
Old Jul 25, 2008 | 07:20 PM
negcamber's Avatar
I still have the air pump.
Old Jul 26, 2008 | 09:32 AM
EVAN&MONICA's Avatar
Damn S/C F20 miata, wuts that thing weigh???
Old Jul 27, 2008 | 11:36 AM
S-Turn AP1's Avatar
sounds like a bad ground, it will reset and read zero if the power is cut off and reconected while the car is moving. The extra g-force after the supercharger install could be causing it, also is it a vortec S/C ? the control box is mounted under the dash on the computer side ( not sure in your case since it's in a Miata ) Maybe the wires got moved.
Old Jul 28, 2008 | 09:08 AM
neeman77's Avatar
Yes, if I turn off the car while I am rolling and turn in back on in gear the speedo goes back to normal. I also have found that certain partial throttle %'s will make it come back on which is weird. I figure its a bad ground, its just odd that it did not show any issues until now.
Shaney
Mar 30, 2015 04:00 PM
nartnailuj
Jul 30, 2010 11:47 PM
05Silverbeast
Jun 18, 2009 01:58 PM
indys2ki
Mar 27, 2009 03:29 PM
BondoBuilder
Jul 30, 2007 12:53 PM
