Electrical/electronics experts
Originally Posted by MsPerky,Sep 17 2009, 07:37 AM
So what happens if the ground is positive when it should be negative or vice versa? Does the sound system simply not work, or is there some kind of explosion?
The converter, in theroy, allows you to attach the negative ground radio to the chassis directly and power it through a converter that steps up the voltage to 24 volts.
Originally Posted by hecash,Sep 17 2009, 11:10 AM
No, inverter.
You are putting in 12 volts at one polarity and getting 12 volts out at a reversed polarity. It inverts, not converts. You still have 12 volts DC.
If you put in 12 volts and got 5 or 15 volts out, that's conversion (step-down conversion or step-up conversion, respectively).
As I understand the logic, the modern radio is looking for a +12 volt difference between ground and power. If the chassis is positive ground, then the power is a negative value and the radio does not work (actually shorts out). The coverter steps the hot side up to 24 volts so that the radio gets the 12 volt difference. As I said in my first post, I'm not sure this is accurate. It just makes sense to me as a layman.
Update. I called the people who sell the inverter-converter at the bottom of the linked page and talked with them about it. they have been in business for several years and sell a bunch of these. I bought one. I'll let you know how it works out.
Originally Posted by Matt_in_VA,Sep 17 2009, 03:37 PM
Something like that, but no explosion. If one hooks the battery up backwards on a British car the horn sucks and the lights casts shadows.
There it passed - I'm fine now.
Tiwe
Apr 22, 2004 12:19 PM
