Motor Oil And Your Car
This morning one of my colleagues mentioned that he had brought his car in for an oil change and the mechanic told him that if the manufacturer recommends either synthetic or dino oil you have to use the recommended type. The reason he said is that the car's sensors are set to recognize the type of oil and using anything else could cause problems with the sensors and the car's computer. I'd never heard that. In fact I've always been told that the choice between synthetic and dino oil was a user preference and it had nothing to do with the car's sensors.
Have you heard anything about this. Do you have to use the type of oil recommended by the manufacturer?
I suspect it might have to do with the vehicle manufacturer.
What kind was he referring too?
type is also a very broad description.
gear box lube is still a "type of oil" but I'm fairly sure I wouldn't put it in my crankcase.
on my MB's I've added oil near the end of the oil change interval and the time to service has gone up.
so they are looking at something.
What sensors? The only one I am familiar with is the oil pressure sensor and it can't tell the difference.
I assume that modern oil change interval monitors are based on mileage and how the car is driven over those miles. I suppose if there was, in fact, a set of sensors that somehow "read" the condition of the engine oil, they might be somehow sensitive to synthetic vs dino.
Good question for that Engineer "son". These new cars get more complicated all the time but I highly doubt things have reached the point where they must have the mfgr's recommendation. Like you, I think its just a dealership being proactive.
I happen to agree with you. I think his mechanic was just trying to sell him a bill of goods.
If they recommend full synthetic and you don't use it, you're on your own on the warranty.
My guess is that the mechanic meant the oil change minder. They work off mileage and start and stop cycles. They don't actually "sense" the oil, but the mileage calculations are based on the recommended oil. If the oil minder is set up based on synthetic and you use conventional, you will exceed the service interval before the minder goes off.
