To roll or not?
Old Apr 23, 2009 | 03:57 PM
S2KCDN's Avatar
Default To roll or not?
I put new shoes on "Precious" this week --18"x9/os55 and 18x8/os48 OZ Superleggras with Dunnie 225/40 + 265/35's. I think they look sweeeeet! I would show you some pics of them but it seems I ain't got the whiskers to post pics since I am only a lowly "guest". Anyways that's beside the point.
I had asked advice earlier about whether lowering the car was a viable option with the new shoes. I would say 95% said not to which turns out to be good advice. I took the "S" for a little spin along the west side of the lake, driving in a spirited fashion (not stupidly) This road is paved well enough but with lots of twists and turns, not something I would encounter on most major routes. I experienced tire rub on hard corners and dips in the road something I would rather not have. A simple remedy that came to mind was to lose a bunch of weight. I am 6' and weigh in a bit over 200 ( Okay! maybe bit more) and mostl of the rubbing is on the driver side . Hmmmm! Go figure. Barring going on a 3 year diet exclusively of raw vegetables my other option seems to be some body work.
Fender rolling has been recommended but usually by some young bucks looking to rice up their ride so I thought to ask some old f*rts like myself tempered by a few years of hard earned experience what they thought of fender rolling?
Old Apr 23, 2009 | 04:33 PM
zzziippyyy's Avatar
you dont need a 3 year diet to lose weight. I have dropped 60lbs + in less than 4 months.
As far as the rolling it can be done without damaging your car, just go slow at it and be careful take your time. A lot of s2000's have rolled fenders. If you think about it you cannot visibly see the difference between a rolled fender and a non rolled fender unless you look up at it while laying on your back.
I say go for it and if you need to buy a fender roller here is a link
http://www.harborfreight.com/cpi/ctaf/disp...temnumber=98793 I even bet they ship to canada
Old Apr 23, 2009 | 05:08 PM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
Sorry to hyjack,but,Zzziippyyy,please post pics,of before,and after...
60 pounds in 4 months...
How did you do that ???
Old Apr 23, 2009 | 05:28 PM
zzziippyyy's Avatar
Emil check here,
https://www.s2ki.com/forums/index.php?showt...&#entry15611510
you saw me at the noreaster i gained another 10lbs after
im a photographer so i dont jump in front of a camera but there was a pic taken of me about 3 weeks and 10 lbs ago its in this thread
https://www.s2ki.com/forums/index.ph...&f=15&t=685727
and referenced by Bass here
https://www.s2ki.com/forums/index.php?showtopic=685730
back to the OP topic now...
Old Apr 23, 2009 | 06:01 PM
How did you achieve this ???
Give us your recipe,in a separate thread,please....
Old Apr 23, 2009 | 06:14 PM
zzziippyyy's Avatar
Emil its all in my post above
Old Apr 24, 2009 | 04:17 AM
matrix's Avatar
I have the exact same street set up and use the same tire widths on the stock rims for track. Stock suspension and not lowered. I am also about 6' and 210lbs (maybe were brothers! )...
No rubbing on or off the track.
Old Apr 24, 2009 | 05:00 AM
zzziippyyy's Avatar
Matrix you have a 2002 S2KCDN you have a 2006
The stock spring rates are different for your years. Are you both running stock suspension?
Below are the spring rates per year for stock suspension
OEM Spring rates by year (front/rear)
MY00-01 = 218/291
MY02-03 = 240/230
MY04-07 = 256/207
MY08-UP = 274/225
MY08 CR = 375/264
Old Apr 24, 2009 | 06:35 AM
matrix's Avatar
Not a big change in the rates....
Old Apr 24, 2009 | 07:00 AM
S2KCDN's Avatar
Hey Zippy,
Thanks for the spec's but maybe you can interpret them for me?
