About to use PC for the first time...
Old Apr 19, 2006 | 10:28 PM
SDCJ's Avatar
Default About to use PC for the first time...
Realizing that Berlina should not be handled only by hand I bought my PC, pads and some new polish and will do my first detail with it this Saturday. Do any of you crafty vets have any last minute suggestions for use on the S? It will be tough for me to mess up my paint, right? I'm just nervous I think...Thanks! Chris
Old Apr 20, 2006 | 01:29 AM
SB2k's Avatar
hey im thinking about getin a PC also for my berlina... let me know how it comes out and if it was worth it... good luck
Old Apr 20, 2006 | 02:53 AM
d-j's Avatar
d-j
Never press down, allow the weight of the PC to do the work.
You will love the way Berlina looks after. Take some before & after pics!
Old Apr 20, 2006 | 05:33 AM
s2ksimon's Avatar
go slow, take your time and don't expect miraculous results off the bat..
but on the other, its NOT hard to screw things up as it doesn't have the power of a rotary
Old Apr 20, 2006 | 09:58 AM
diabolus2k's Avatar
You really can't screw things up with a PC... you'd have to try really hard to. Just start with the least aggressive polish and a mild polishing pad and see if that gets the job done for you. If not, then step up to a more abrasive polish/pad combo.
Work in 2x2 sections, start the PC off at speed 3 or 4 to spread the polish around and then move up to speed 5 or 6. Move the PC slowly across the paint, and don't be afraid to apply a little pressure. Wipe the area with an MF towel and some detailing spray when you're done, and check your work under a halogen or fluorescent light. Each car's paint is different so it might take you a little while to get used to what polish/pad you'll need for any given situation. Personally, I recommend Menzerna or Poorboy's polishes
Old Apr 20, 2006 | 10:59 AM
thetz99's Avatar
Make sure you spritz the pad face with a detail spray before every run to lube the pad. Supposedly will guarentee no paint burn even with a rotary.
Old Apr 20, 2006 | 11:09 AM
SDCJ's Avatar
OK, I didn't see that in the instructions...I should spritz the pad before I put the circle of X of polish on? Thanks for all the above as well...
Old Apr 20, 2006 | 01:57 PM
diabolus2k's Avatar
^^ Yes, spritz the pad before you put the polish on. You only need to do this once right before you begin polishing
//steve\\
May 15, 2011 05:30 PM
JoeyBalls
Jun 4, 2010 03:03 PM
evolammy
Car Talk - Non S2000
Jan 8, 2008 05:15 AM
kctheflish
Mar 7, 2007 04:17 PM
dut
Nov 20, 2004 02:54 PM
