Bringing fender liners back to life...
Old Dec 4, 2010 | 05:56 PM
FISH22's Avatar
Default Bringing fender liners back to life...
The one thing I can't stand after a full detail, are the horrid, dried out fender liners. Over the years, I've tried a few things. And lately, I've tried Adam's Invisible Undercarriage, and Adam's In and Out spray. They both do great, but just for a little bit.
Obviously, I can just buy brand new fender liners and solve this whole problem, but that's going to be pricey. I've thought about possibly spraying them with a semi-gloss paint, or maybe even some undercoat spray?
Any thoughts on this guys? Not sure how well a spray paint would adhere to the plastic though, and possibly how well it would hold up.
Old Dec 5, 2010 | 04:59 AM
Vanishing Point's Avatar
You may be already doing this, but do you clean the liners first? I remove my wheels and then wash the entire inner fender with a good APC, water and some brushes. I wash any exposed suspension bits before applying a undercarriage spray,etc.
I too use the Adams Undercarriage spray and even have tried the VRT with good results. Whatever you use the initial key is prepping the surface prior.
Old Dec 5, 2010 | 06:38 AM
Burgman's Avatar
Tire foam spray also works well on fender liners.
Old Dec 5, 2010 | 12:09 PM
slanguage's Avatar
Cleaning them with a good degreaser and a stiff brush. I dress wheels wells with Chemical Guys Bare Bones.
You can buy a spray-type rubberized undercoating, but the rear wheel wells are the ones with that in them. Not sure how thyat would look on the front ones though.
Old Dec 5, 2010 | 01:17 PM
NFRs2000NYC's Avatar
Lower your car, problem solved.
Old Dec 5, 2010 | 02:04 PM
FISH22's Avatar
It's definitely as low as I'd want it to be. Plus, I'm running 17x9 +45 w/255 tires up front. So that definitely helps in covering some of the liner up.
Old Dec 5, 2010 | 04:30 PM
On a more serious note, be very careful with the AMOUNT of dressing you put on the lines. Many people want them sexy black, and spray a shitload of dressing on them. All good right? Wrong. In the rain, the water will mix with the dressing, and drip onto your tires, essentially covering them in a film of oil. Get them as clean as you can with a brush/degreaser/soap, dry, spray on whatever blackness you want, and call it a day. It's a car you drive, keeping the liners clean is a losing battle.
Old Dec 5, 2010 | 05:52 PM
akimel's Avatar
I have not found a wheel well dressing that lasts too very long. At the moment I am using Griot's Undercarriage Spray on my wheel wells. It seems to do a good job. But it only really lasts a couple of weeks. Fortunately, our S2000 (front) wheel wells are not that too terribly exposed.
Old Dec 21, 2010 | 11:02 PM
Picturepro's Avatar
I just pulled out the front liners and used a couple cleaners simple green and some Orange cleaner. I was not sure what to get them back to rich black. I've used spray silicone on plastic parts in engine for +5 years. no probs there it looks almost new with 94000 miles.
IwantanS
Feb 18, 2015 11:44 AM
S2Ko0o
Nov 19, 2012 04:48 AM
cmc600rr
Apr 9, 2012 10:28 AM
yals
Feb 4, 2011 12:24 PM
zeroptzero
Jan 18, 2011 06:25 PM
