Cleaning before Shin-Etsu?
Old Oct 5, 2001 | 04:06 PM
Bluescreen's Avatar
Default Cleaning before Shin-Etsu?
Before applying Shin-Etsu lube, do you guys/gals do any special cleaning or prep? Is a rubdown with a damp cloth adequate, or should I use some sort of cleaner?
Thanks,
Mike
Old Oct 5, 2001 | 04:17 PM
xviper's Avatar
Whatever grease you use will most likely be a silicone base, Shin-Etsu included, should in itself act as a cleaner. However, if the seals are particularly dusty or dirty, you may want to wipe them down with warm mild soapy water, dry, then apply the grease. This will use less grease. I use the Silicone Emulsion sold by GM and it is applies with a built in applicator. Once the grease has a few minutes to soak in, I wipe away the excess, done.
Petrol-Head
Apr 1, 2011 02:16 PM
ayS
Apr 8, 2005 07:04 AM
su2ny
Jun 12, 2003 04:24 AM
lostsol
Nov 20, 2002 08:37 PM
