cleaning tire scrubber
I washed my car's exterior today and after hosing down the tires I decided to scrub it with a specific tire scrubber. When I was done I saw the scrubber was filled with grime and dirt. I tried hosing it off with my high pressure hose but it wouldnt come off. I also tried "Greased Lightning" (the purple bottle) and then hosing it off but it also doesnt work.
Any suggestions ?
Any suggestions ?
Originally Posted by trivium,Dec 3 2006, 09:17 PM
yeah but next time I clean the tires- which will most likely be with a dedicated tire cleaner- it wont be perfectly clean since the brush has reasonable amounts of grime in it.
what are you using on your tires to give them some shine?
the problem that you describe is pretty normal with several tire protectants...
and as mikeyc says, its not likely to effect your cleaning ability.
Been using the same tire brush for about 15 years. Originally it had white bristles in the center and yellow bristles around the edges. It is pretty much two shades of gray today, but it varies from black to gray with use. Black is from cleaning tire/wheel that have been near leaking seals. Brush still cleans just fine.
I use a bucket of hot water with Joy for wheel cleaning. Brush and wheel mitt are in the bucket of Joy. Tires get sprayed with Mean Green, brushed, and wheels get washed in Joy. Occasionally I treat tires with Zaino UV protectant.
