The differences between the Porter Cables
Old Sep 26, 2007 | 05:58 AM
detailersdomain's Avatar
Former Sponsor
Default The differences between the Porter Cables
I figured that this was a good article to post for you all....
This article covers the following Porter-Cable tools:
The 7335 5" & 7336 6" Random Orbit Sanders and the 7424 Car Polisher.
These tools are essentially identical in that they all use the same body. The difference lies in how these tools are outfitted. Therefore, if you own any one of the above models you have the capability to convert it into either a 5" or 6" sander/polisher. But before you can proceed you must understand that depending on the pad diameter one of two counterweights is used.
The counterweight is a half-moon shaped piece of metal attached to the rotating shaft of the tool. This smooths out the random orbit action by providing a counter balance to the elliptical orbit of the rotating backing pad. If you change the pad size you must also change the counterweight or suffer unnecessary vibration and possible damage to the tool.
There are two different counter-weights which are clearly marked to indicate use with either the 5" or 6" backing pad. Therefore if you decide to outfit the 7335 5" Sander with a 6" backing pad for sanding or polishing you must switch to the counterweight used with 6" backing pads. The same goes for the 7336 6" Sander. If you decide to outfit it for 5" sanding or polishing you must switch to the counterweight used with 5" backing pads.
Porter-Cable 7424 CAR POLISHER The only exception is when using the 54745 6" Foam Polishing Pad. Due to its light weight and the small-diameter backing pad used (included with pad), it can be used with the 5" or 6" pad counterweight. Porter-Cable outfits the 7424 Car Polisher with the 5" pad counterweight.
Old Sep 26, 2007 | 08:12 AM
wanabe's Avatar
nice summary phil...
Old Sep 26, 2007 | 09:36 AM
Former Sponsor
Thanks!
Old Dec 30, 2008 | 06:44 AM
RUGBY's Avatar
Phil & other Wackos,
Which counterweight would you suggest of a 5.5 pad?
I have PC7336 w/ 6" inch counterweight. I have been using 6" Edge Pads but recently purchased a number of CCS 5.5" pads.
Given Detailers Domain buy one/get one sale, I was going to pick up a few more but want to ensure I'm using the proper counter weight.
I'm using the Flexible Backing Plate for the Porter Cable (5 - 5.5 inch) from Phil's site.
Thanks in advance.
Michael
Old Dec 30, 2008 | 07:34 AM
Former Sponsor
You can use either the 6 inch or 5 inch counterweight with the 5.5 inch pads.
Old Dec 30, 2008 | 10:14 PM
qbmurderer13's Avatar
Would the counterweight see any benefit when using 4" pads? Or is it not even possible?
Old Dec 30, 2008 | 11:22 PM
Former Sponsor
I don't believe so. I just leave whatever I have on the machine in there.
Jeremy Clarkson
Jul 11, 2013 01:12 PM
sillyboybmxer
Aug 9, 2010 11:12 AM
ade73
Apr 8, 2006 10:43 AM
brian_k03
Apr 28, 2004 07:02 AM
wanabe
Sep 16, 2003 07:36 AM
