Finally ordered my Porter Cable :)
Hey guys, I am tired of "hand" detailing my car for hours only for it to look somewhat ok at certain "dark lighting". I ordered it from DD under the Group buy, I also ordered the 4-pack of pads, Orange, yellow, White & black
1) Orange is cutting? Yellow=???????? White=polishing?, black= finish (waxing)
The order is????
1)Light cutting
2)Polish
3)Glaze
4)wax
Also what is the best way to remove the wax? I have some shitty Pep buy random orbital buffer that I bought for like $40.00 a couple of years ago, should I just buy some MF bonnet and use that buffer to remove the wax?
Thanks fellas
The order is????
1)Light cutting
2)Polish
3)Glaze
4)wax
Thanks fellas
Originally Posted by mattfeet,May 18 2008, 08:23 AM
You can remove wax using dish washing detergent as a soap. But be aware that this will entirely remove it.
Yellow- Compounding
Orange- Polishing
White- Light Duty Polishing
Black- Finishing
-Matt
Yellow- Compounding
Orange- Polishing
Black- Finishing
-Matt
Not strip the wax, just remove the applied dried wax
Unlike a chemical polish or abrasive polish, a glaze does not clean or abrade the paint. A glaze typically contains oils and kaolin to fill and mask minor imperfections remaining after polishing, and to enhance the brilliance of the finish. If a glaze is applied, it is used after use of a chemical polish or abrasive polish or All in One product but before application of a sealant or wax.
-Matt
-Matt
two things, don't use dish washing soap on your car and you can throw your $40 buffer away as you won't need it anymore. unless you applied the current wax recently, a good wash, clay, and polish with pc should remove the previous wax. as for applying and removing wax, i usually do that by hand. but with a black pad and a low speed you can apply it with the pc and remove it with your favorite mf towel.
