HELP! Leaking roof
Just as the description says, I have water seeping through at the corners where the roof, A-pillar and window meet. Its coming in at both corners. Is there anything I can do or do I need to change the weather proofing seals? Also, could it be the strikers that are'nt pulling the softtop as tight as possible to channel the water into the little channels in the rubber?
Cheers
Andrew
I take it this is something that has just started since you have an older car?
Have you ever done any regular maintenance on the rubber seals? It might be long overdue and might even be too late. Any window rubber seal on any car needs silicone grease treatment at least annually.
I had the car since last april. Unfortuneately it was in the garage for 4 -5 months having an engine rebuild. Just got it back in December and greased the seals, but its started to leak again. I suppose the previous owner didnt really look after it. If its too late, what would I need to do?
Andrew
Andrew
Andrew
Andrew
If this fails, then the seals are toast and you'll have to look into getting replacement seals.
You may need to get the windshield frame seal and the first section of soft top rubber seal.
Originally Posted by xviper,Jan 27 2006, 09:28 PM
What are you using? A silicone grease or emulsion is best. Apply a layer on, leave it for several minutes to soak in before wiping off any excess.
Cheers Xviper
Andrew
Might also check the strikers. I was having this problem and replaced the strikers with hardtop strikers (~$50 from hardtopguy), as well as greasing the seals with Shin Etsu grease ($12 from the dealer).
My old strikers looked like this (after swapping sides at one point) and weren't holding the top down all the way:
Originally Posted by delliot,Jan 28 2006, 08:20 PM
If you get new strikers, get the ones intended for the hard top they hold the top tighter. This is a fix for a rattling top from Honda...
*I* would consider it an easy DIY job.
See this link for a diagram:
http://www.hardtopguy.com/store/customer/p...p?productid=250
Basically you have to remove the plastic trim piece on the underside of the windshield frame. To do that, you start by:
- removing the map light shield, map light assembly (a could of phillips screws and clips)
- removing the visors (a screw or two each)
- the two a-pillar trim pieces on either side of the windshield
... pull away and up from behind the edges of the dash or simply pull the top away enough to get at the main piece
- top trim piece - pull down and away.
- two phillips screws on each of the strikers and put it all back together
30 minutes top.
30 minutes top.
