How to clean the door hinge area
I just noticed today as I was getting out of the car that the door hinge is really dirty. I am talking about the joint between the hinge and the car body, not the part that swings. It seems there is some kind of glue-liked material applied to the hinge before it is bolted onto the car body. When the car was new, it was all clean and clear. But now, after 3 years, it has become gray/yellow and dirty. So what is the best way to clean this area? I can't open the door and then spray water on it -- water would get all over the seats and carpet in the car.
Also what kind of cleaning material should I use for this area? I am pretty sure that I don't want to wax the door jams, but do others do it? Thanks.
after washing, i always dry the "hidden areas" with a cotton rag. fuel door area, inside trunk area, doors ,and last underhood area. (actually, last is the metal inside the wheel wells and all around the bottom of the car- including the strakes). in fact, i use that damp rag to then wipe down the entire engine compartment - keeps the car new all over.
I mostly do what wanabe does also (except I don't clean the wheel wells and under the car). But no matter what I do, I still cannot get the "glue-liked" stuff at the door hinge clean
. I've tried wiping it, squirting detergent at it, etc. The glue has turned from a clear/yellow color to grayish black. Since I have a GPW, the dirt just shows up so much worse.
Help
Help
are you talking about grease?
several products would work, but the one that i would use first would prob be goo-be-gone (cause i use it for difficult to remove stuff, and cause its safe- just citrus). be sure to rewax the area after you clean it.
ruexp67
May 21, 2003 01:31 AM
