How do I know when I've worked a product fully?
they each have slight differences, but the common characteristic is either the product dries and dusts or it just isnt there anymore- polishes break down as you use them. when they are fully broken down is usually when you are finished. always read the product instructions to see if yours has any special characteristics.
Which product are you using?
As wanabe said, some (most) go to dust. Others (Zaino ZPC, etc.) just are no longer visible. You will find that the amount of time you can work a polish will greatly vary with heat and humidity.
Now there is something to be careful of - flashing and being broken down are two different things and one is not indicative of the other.
A product will often flash if conditions are not right way before it is fully broken down. This can be a big issue with some of the Menzerna products on a warm surface or in sunlight. When the product flashes, it just means that the heat on the panel, heat in the air, heat from the equipment, and humidity have caused the wet/volatile/liquid portion of the polish to go away. To fight this, many will mix a glaze in with the polish to increase the working time. Personally, I use Clear Kote Red Moose Glaze for this.
When a polish is actually broken down, the abrasives have been divided enough times to be of such a size that their marring is minimal (PB SSR) or virtually invsible (Zaino polishes).
-GT
-GT
-GT
-GT
You are correct in your explanation of flashing/breaking down, however IME polishes that are broken down tend to flash a lot quicker.
I am using Optimum Compound and Optimum Polish.
Unfortunately I don't have a garage or enough shade to work out of at least some sunlight - I live in an apartment.
Thanks for the info so far. I think I just need to work
Would I be better off switch to Poorboy's product line (heard they work in sunlight).
Also, can you explain how to mix in a glaze to prolong working times/
