How do you clean foam buffer pads?
Old Mar 10, 2012 | 11:42 PM
SpacemanBrent's Avatar
Default How do you clean foam buffer pads?
Bought a Griot's orbital buffer kit from Detailer's Domain and expect to receive it in the next couple of days. I didn't buy any cleaning solution when I placed my order. Can I throw the pads in the washing machine until I buy some cleaning solution? What do you guys recommend?
Old Mar 11, 2012 | 12:07 AM
dwight's Avatar
I've read that machine washing is OK, but don't throw them in the dryer. Just air dry them.
Old Mar 11, 2012 | 08:58 AM
Vanishing Point's Avatar
I use the Grit Guard pad washer. The best system I've found to thoroughly clean your pads.
http://www.gritguard.com/the-universal-pad-washer.html
Old Mar 11, 2012 | 11:40 AM
metros's Avatar
Previously I used to rinse thoroughly, soak in dishwater, rinse thoroughly again, and then air dry.
However, I just picked up some pad cleaning solution that I'll be trying this summer.
Old Mar 11, 2012 | 12:04 PM
akimel's Avatar
The pads I got from Meguiar's are machine washable, but this is not the case for all pads. Best to check with the manufacturer. I soak mine in Dawn dishwashing solution and then throw them into the washing machine.
Old Mar 11, 2012 | 03:13 PM
sillyboybmxer's Avatar
pads hold soooo much product i wouldnt wash them in the washing machine, that stuff will get stuck to the sides and end up on your clothes. i soak right away in dawn dish soap and then massage the pads to squeeze it out of the pores and repeat until its all out
Old Mar 11, 2012 | 06:16 PM
importkid's Avatar
Originally Posted by sillyboybmxer
I soak right away in dawn dish soap and then massage the pads to squeeze it out of the pores and repeat until its all out
Old Mar 12, 2012 | 12:35 PM
S2KRAY's Avatar
Active Streak: 30 Days
Top Answer: 1
I use a cleaner from my detail supplier (powder) added to warm water. Then I have a tool which runs across the pad while it is spinning on the buffer.
Old Mar 12, 2012 | 06:24 PM
jwr0ng626's Avatar
^can you save the mixed solution for next use? or is it pretty much 1 package mixture per pad per use?
Old Mar 13, 2012 | 02:15 AM
dwight's Avatar
The instructions for Snappy Clean say one packet per 3-4 gallons of water. Replace solution weekly or more often with heavy use.
