How to remove engine oxidation marks
Old Mar 8, 2009 | 09:18 AM
S2000_FUN's Avatar
Default How to remove engine oxidation marks
Hello,
Can you please tell me how to remove and what cleaning kit to use in order to remove marks in the outer casing of the engine that developed from road salt?
Please see the attached photo and advise me what is the best i can to clean the casing
Thanks
Chris
Old Mar 8, 2009 | 09:30 AM
midnightsunset's Avatar
WOW! That looks pretty bad.
Old Mar 8, 2009 | 09:50 AM
espelirS2K's Avatar
Try a heavy degreaser like megs super degreaser or something. And a lot, LOT of elbow grease..
Old Mar 8, 2009 | 11:38 AM
krshultz's Avatar
If degreaser doesn't work, I'd try some #0000 steel wool. If that doesn't get it, bump up to #00 steel wool.
I don't think I've ever seen a diff. cover get quite that bad. I'm confident you can make it look nice again, but it probably won't be a real fun job.
Old Mar 9, 2009 | 01:44 AM
Sideways's Avatar
Originally Posted by S2000_FUN,Mar 8 2009, 10:18 AM
Hello,
Thanks
Chris
Use a buffing wheel.
Old Mar 9, 2009 | 11:00 AM
krshultz's Avatar
God that looks GREAT.
Old Mar 9, 2009 | 11:11 AM
S2000_FUN's Avatar
Use a buffing wheel
Can you saw me one?
Chris
Old Mar 9, 2009 | 11:14 AM
Sideways's Avatar
Too much work. I'm doing another one now and it is truly too much work.
Old Mar 9, 2009 | 07:03 PM
jlb85's Avatar
The diff cover is aluminum, which oxidizes in air and creates a white powdery residue that is very had to remove. So basically to get the diff cover looking like new, you will have to strip it with a wire brush or buffing wheel or sandblasting of something like that. Further, it will go back to looking that bad in the future if not maintained, and some oxidizing is inevitable.
Polishing helps to reduce the formation of oxides in this case because it actually reduces the surface area of the metal, leaving less areas for oxide to form and to stick to. But even polished Al will oxide quite easily.
BTW, the oxide serves to protect the metal :/
Another option is to spray paint it. I have used some aluminum color paint for calipers and such that make the part look like brand new cast aluminum, and lasts for a long time... if interested I'll look it up...
Old Mar 9, 2009 | 10:23 PM
SquirtleS2K's Avatar
Haha.. yea, I was thinking you should just paint it
