I need more shine
Old Feb 17, 2008 | 01:29 PM
CarbonS2000's Avatar
Default I need more shine
Ok so I started refinishing the lips of my wheels. I started with 800 sand paper then moved to 1000 then to 1500 and finally 2000. I sanded it all wet. It took me about 15-20 mins to do each level of grit. I took my time and I didnt want to miss any spots. After 2000 I dried the wheels and used Bluemagic wheel polish cream. I worked it in and then used a micro fiber to remove the dirt. The lips look 10x better but they arent as shiney as I'd like them. Is it bc of the sanding or the polish? I trieed polishing a rim that I havent sanded yet and they look brighter than the wheel I sanded already. Any thoughts? Heres some pix to show the before and after.
before:
After:
Notice in teh after pix...the rim doesnt really have a great luster. What can I do to improve that? Thanks for the help!
Old Feb 17, 2008 | 01:51 PM
Jaeden09's Avatar
Wax?
Were they clear coated?
Old Feb 17, 2008 | 01:55 PM
No I dont think they were....If they are clear coated how should I go about sanding them? Should I maybe start with 400-600-800-1000-1500-2000? Do they make a finer paper than 2000?
Old Feb 17, 2008 | 02:28 PM
EOE's Avatar
EOE
if its clear coated you don't wanna go through the clear so using anythng below 1000 I would think twice about. :-/
You could try 2000 gritt because it will be easier to remove with regular polish. Honestly I think you need a buffer to make them sparkle. You can do only so much by hand.
Old Feb 17, 2008 | 02:46 PM
I have a buffer machine. I just tried rubbing compound. I working it in with my hand and removed it with the buffer. Then I used my metal polish and worked then in by hand, removing it with the buffer. So much better. I have to do the inner part of the lips now. For that, I can work in my compound and polish by hand and use a powerball mini to buff it out. Then I would go back and use the polish and wipe and buff with a micro fiber. Looks like I have my work cut out for me. Good thing Im off from work tomorrow.
Old Feb 17, 2008 | 02:53 PM
EOE's Avatar
EOE
Cool man keep us posted. Can't wait for the final results. You right tho, the spokes need some good buffing, granted they are white.
Old Feb 17, 2008 | 02:54 PM
Jaeden09's Avatar
Well, for starters... The purpose of a buffer is, well, to buff... Use that instead of working it by hand. What kind of polish are you using? I would never go below 1000, or even 1200.... I start out at 2800 IIRC when I worked on my paint.
What kind of polish is it (As previously mentioned)?
What kind of polisher?
Old Feb 17, 2008 | 02:59 PM
Wheel polish is Bluemagic wheel polish cream. Polisher is more of a buffer machine I got from pepboys for like $25. I want to get a porter cable in the near future.
As for the paint. I am not using sand paper on them. I wash the wheels with wheel cleaner (meguiers), sand/polish my lips, then re-wash with p21s and scrub the entire wheel. I havent washed the wheels with the p21s yet.
Could you recomend a specific polisher machine if not a porter cable?
Old Feb 17, 2008 | 03:28 PM
EOE's Avatar
EOE
https://www.s2ki.com/forums/index.php?showtopic=552806
Apparently thats like best tool out there after reading reviews of this product.
Old Feb 20, 2008 | 09:40 PM
Toney's Avatar
2000 grit is not enough...
I polished a motorcycle frame and forks by myself as a first project and sand paper goes all the way past 12000 grit...at that point it feels like a piece of rubber to the touch but 8000, 10000 and 12000 are the points where it comes to a mirror shine...
Grit levels this high are rare to find in a home store, you may need to order off the internet.
raftaman
Aug 23, 2018 01:30 AM
rtbiscuit
Apr 1, 2011 05:29 AM
dan_uk
Jul 30, 2009 08:34 AM
Si2k
Mar 30, 2009 10:31 AM
zbrewha863
Sep 1, 2007 09:11 AM
