Light white haze
Old Feb 24, 2003 | 10:25 PM
intimidator2000's Avatar
Default Light white haze
I have a light white haze on my car can only see the white haze in the sun but when I wash the car will the haze go away.
Old Feb 25, 2003 | 01:27 PM
VinceD's Avatar
Try washing your car and the haze should go away but if it does not then try waxing/polishing/detailing and if that does not work the problem is deeper than usual and you may have to re-paint your car that's the best answer I can give you maybe someone else will have another idea.
Old Feb 25, 2003 | 03:05 PM
wanabe's Avatar
do you cover your car?
the cover will cause a haze after several coverings if the car is not completely clean. it is first noticeable on the rear deck (trunk).
when this happens to me, i dust the car and use a detailers spray to clean off the haze.
Old Feb 25, 2003 | 05:45 PM
The mistake I made is I washed my car in the sun when I was done then I saw the white haze.
Old Feb 25, 2003 | 07:25 PM
wanabe's Avatar
sounds like it could be minerals from your water...
if it doesnt go away with a good washing, then you will have to try polishing (not waxing- polishing is the step before waxing... polishes can contain mild abrasives) and then zaino/synthetic or carnuba finish.
and i guess i dont have to suggest that you never wash your car in the sun again!!!
Old Feb 25, 2003 | 11:35 PM
So the haze should go away with a good washing.
Old Feb 26, 2003 | 05:10 AM
William's Avatar
The sun dries the water off the car leaving behind soap and/or water mineral residue before you have time to dry car yourself. Never wash your car in direct mid day sun. And yes it should go away after a good washing, especially if you have Zaino (or a good wax coating) on your finish.
Old Feb 26, 2003 | 02:51 PM
F20C_S2k's Avatar
I have the same problem...trust me it's just the way the light hits your car!! it 's only in the direct sunlight and cetain angles you see this haze right?
Old Feb 26, 2003 | 04:31 PM
paivag's Avatar
Zaino Z6 detailing spray after car wash with the car still wet. Should take car of this... Or just use any detailers spray...
Old Feb 26, 2003 | 06:10 PM
F20C_S2k what you said is right but when you washed your car did the haze go away.
zeroptzero
Aug 14, 2014 03:35 PM
willinathen
Sep 14, 2006 08:13 PM
