Minimum temp for Zaino application.
This will be my 4th season using Zaino polish but I can't remember the recommended minimum temperature for application. I figure if it's sunny out 50's and I'm parked in the sun I should be O.K. Opinions?
FYI: the new z2PRO has much better drying times.. than the old z2 and z5
i coated my car with z2 pro x 5 past weekend..
i splashed some one in the low 40's and it dried within 30mins..
wiped it off no problem with an MF towel..
Originally Posted by wanabe,Mar 29 2005, 07:20 PM
sal says you can apply to 45 degrees...
the cooler the temp the longer the cure time-
and i avoid the sun on the car.
so 50 degrees is fine
But with the new z2 PRO, it cures (ie finger swipe test) much faster .. no joke.. I cannot believe this stuff !! Kudos to Sal !
I live in Winter country predominantly where now at this time of year our day time highs or 37 to 39 F and z2 PRO just works amazingly fine..
I can't wait for the warmer temps, probably add another 30 coats at this rate
