My girlfriend threw up in my s2k
#22
Originally Posted by ThuG LyFe,Oct 29 2009, 07:51 AM
had a close call once...luckily she knew how anal i was about the car and opened the door when we were stopped.
at least you're better off than this guy:
http://www.g35driver.com/forums/picture-sh...my-dog-did.html
#23
House rule #139
You throw it up, you clean it up.
Or get her to pay for a interior shampoo at a car wash place for ~50bucks. I had one of my trucks shampooed when I left the windows down overnight while camping and the whole thing smelled like smoke
#24
•Use a rubber bristle brush go over the carpet material to raise the fibres
•Vacuum area very thoroughly to lift all the loose dirt from the carpet
•Remove any stains with a ‘spot’ remover (303™ Spot Remover & Cleaner)
•Spot treat really bad stains (303TM Cleaner & Spot Remover or Woolite® Heavy Traffic Carpet Foam)
•Use a pre-cleaner solution, 10:1 distilled hot water/ P21S Total Auto Wash, let solution dwell for 5-10 minutes to enable cleaners to react
•After sufficient dwell time agitate pre cleaner solution with an upholstery brush to ‘friction scrub’ surfaces
•Mist spray surfaces with hot water
•Brush the carpet to raise the nap and loosen ground in dirt
•Remove the excess moisture, using a Wet/Dry vacuum (preferably a carpet extractor system) and allow carpets / mats to thoroughly dry before use
•Once fabric is dry apply a fabric protection (303™ High Tech Fabric Guard)
Note: Use the hottest water available it also helps to pre-spray the carpet with hot water when hand cleaning carpets / mats
#25
Hey Rog / others - have any of you tried this 303 fabric protectant stuff? I abandoned Scotchguard years ago. The smell of it gives me a headache, and besides, I'm not convinced that it works.
#27
Or just got to Homedepot buy a Little Green Clean machine, steam clean the carpet and return the machine the next day. They will take it back.
Let the Precleaner soak for a few minutes. done!!!
303 works great.
303 works great.
#30
For the carpets there are simple carpet cleaners you can get from walmart. When my buddy had his own personal exorcism in my house I just used some carpet stain remover. and then vacuumed it up and added some febreeze just to make sure it is gone. As for leather, I would assume some leather cleaner?
Hope that helps man.
Next time keep the top down.
