New to using a PC
Old Dec 31, 2007 | 05:17 AM
demade's Avatar
Default New to using a PC
I am new when it comes to using a PC. Curious about what to use for cleaning my pads. I have seen ads for sprays and powders. Would like to get a feel for what gets the best results.
Also a what point do you retire your existing pads? I am using the Edge system.
When you start are you spraying the pad with anything to dampen it ? If so, can you hit it with a mist of water or detail spray ?
Thanks in advance for any info.
Old Dec 31, 2007 | 05:20 AM
Ubetit's Avatar
For me it's a wash in a bucket with a bunch of dishwashing soap. It's the only thing i've found to get your pads to come out looking like new.
I use my pads as long as they do correction. That usually means as long as there is 1/8 inch of whatever foam you are using on the entire surface of the pad.
I lightly mist my pads from about 18 inches away with one spray of detail spray before starting.
Old Dec 31, 2007 | 07:18 AM
wanabe's Avatar
i do the same... sometimes i use a pad cleaner solution too
like this one:
http://www.autogeek.net/xmt-pad-cleaner.html
Old Jan 1, 2008 | 07:01 AM
demade's Avatar
Thanks much for the info.
Old Jan 1, 2008 | 07:17 AM
motogp1's Avatar
i've ordered one of these .
http://www.detailersdomain.com/index.asp?P...EWPROD&ProdID=5
Ap28k
Jan 28, 2008 09:39 AM
SC2000
May 13, 2007 03:58 AM
juice04
Jun 1, 2006 08:34 PM
Driv300mph
Jun 29, 2005 07:50 PM
HarleyMB41
Sep 12, 2004 07:42 AM
