Paint Gauge
Old Mar 10, 2008 | 09:45 AM
RUGBY's Avatar
Default Paint Gauge
I noticed in a recent post that FMINUS was taking readings with his Defelsko DFT paint gauge.
I understand that if buying a used car, you might be able to determine if the car was in an accident and repainted (at least I've read that).
However, from a detailing perspective, what use is the data and what might might be a corrective action if one reading is 104 vs 122 (as shown in FMINUS's post).
Can anyone shed some light on this topic?
Old Mar 10, 2008 | 10:38 AM
wanabe's Avatar
he (or phil at detailersdomain, or anyone else who uses these regularly) is the best person to respond to this, but i will respond to move it up...
it can also tell whether paint is too thin in an area-
and if you can tell that a repair has been done, you might need to focus polishing in that spot.
more info is here:
http://www.defelsko.com/dft/positest_dft.htm
Old Mar 10, 2008 | 10:53 AM
detailersdomain's Avatar
Former Sponsor
good question the paint meter can give you a accurate measurement of how much paint is on the car.
If I'm right there are usually x microns of clear, x microns of base , and then primer. ( I have to find the typical numbers)
from there you can tell how much paint you can remove and how much you have taken off.
you can correct paint all so much before the clear is gone and you have burned thru the paint.
sscott0203
Nov 7, 2010 06:00 PM
aznives3
Jul 10, 2009 06:30 AM
jonnys2k01
May 21, 2009 05:07 PM
robs_silver_s2k
Apr 25, 2007 06:12 AM
TepEvan
Mar 5, 2003 12:45 PM
