Pine Sap....
Old Mar 28, 2007 | 12:29 PM
VorlonDrow's Avatar
Default Pine Sap....
Well it finally happened. A pine tree was so excited to see my S that he left some sticky clear goo on my car. Im buying a car cover today if i can make it to the dealership in time but as far as removing the sap....any suggestions?
Old Mar 28, 2007 | 12:51 PM
wanabe's Avatar
bad tree!!
wd-40, mineral spirits, or a sap remover are usually my first tries-
tarminator is a good product if you need one that is made for the job
http://www.autogeek.net/tarminator.html
Old Jun 16, 2007 | 03:43 PM
Egg Roll's Avatar
hi wanabe
is wd-40 safe on the paint ? I tried the tar remover on the hood and the bumper but now it gives me that faded water mark on them , is it possible to remove those mark ?
Thanks
Old Jun 16, 2007 | 04:10 PM
wanabe's Avatar
wd-40 is fine for the paint- dont get it all over the car, just the area that needs it
it will remove your wax, so you will have to rewax when you are all through getting the stains off.
for the mark, first try clay- slim chance, but it might work.
then a "paint cleaner" or swirl remover- both are light polishes and they should get anything that the clay cant get. i would do it with a machine, but for a small area you can do it by hand- make sure to finish the polishing front to back-
in our "how tos" at the top of the board are some videos on polishing-
Old Jun 16, 2007 | 06:00 PM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
with MR.Wannabe.
Just removed,one from my trunk,tonight.
Soaked it,(not all over the car...) with WD-40,and remove it,with a MF towel.
Works just fine.
Old Jun 17, 2007 | 08:45 PM
animeS2K's Avatar
on the WD40... also isopropyl alcohol will remove fresh sap.
Old Jun 20, 2007 | 10:12 AM
bcs's Avatar
bcs
Will this process also work on the windows? My girlfriend parked under the tree last night (so I could put my car in the garage. True love right there ). Anyway, this morning there was of course some sap on the window. I would have cleaned it off before I left, but I was late. I just want to make sure that this will work as well on the window.
And...I did not use her suggestion. 'Ooh, just turn on the windshield wipers". haha.
Old Jun 20, 2007 | 10:20 AM
animeS2K's Avatar
yep. it'll work fine on any surface. just make sure to clean up afterwards with a glass cleaner.
JspecVtec
May 7, 2010 09:27 PM
C8V6C
Jul 8, 2007 04:45 PM
slanguage
Jun 30, 2007 07:31 AM
TunedS2000
May 3, 2004 12:05 PM
Switzerland1010
Aug 29, 2003 07:40 AM
