Problem with microfiber towels and wax removal.
Does anyone have problems removing wax with microfiber towels? When I try to remove Z-2 or Z-5 with my mf towels, they leave behind streaks of the dried product. At first I thought it was the Zaino, but if I take my finger and drag it across the surface, I can remove the remaining Zaino. I end up having to spray the surface with Z-6 to remove the remaining product. Has anyone seen this problem before? Any help would be greatly appreciated. Thanks!
yup... ditto the above. the right amount of zaino looks like you didnt put on enough! should be a very light haze.
porter cable makes this a lot easier... but does use lots more product to apply less!
Either too much Zaino or too little drying time.
I will say this - I tried a coat of Klasse SG over the Zaino, and it left a gummy, hard to remove result, so I would not recommend that combination.
Also, make sure you are using the right MF - they are all not the same, - you want the closed loop style (lt blue). The lt green and dark green ones are different. One is for detailing, the other for glass.
