Rear ''Plastic'' window 00 s2k
Old 08-17-2009 | 03:46 PM
RedY2KS2k's Avatar
It's not a trivial task, but the window can be replaced without replacing your top. But that's only an option if the top is in very good condition.
Old 08-17-2009 | 06:17 PM
s.french's Avatar
And How much is the window ? Is it a big thing to change ?
Old 08-18-2009 | 05:53 AM
MurderS2K's Avatar
im finishing up writing a DIY on the cleanest possible rear plastic ever. I used 2 coats exterior and interior of Novus (you really need to put some backbone in this) and followed by a major buff. Then 2 coats exterior and interior of Plexus.
my rear window is brand new
Old 08-18-2009 | 10:07 AM
RUGBY's Avatar
The window is ~US$200. Hardtop Guy (www.hardtopguy.com) carries it.
I believe you can DIY, but it is labor/time intensive. You can search the board. I've seen a couple of DIY's on it.
Old 08-18-2009 | 11:12 AM
s.french's Avatar
Alright thanks
Old 08-18-2009 | 11:59 AM
alSpeed2k's Avatar
I recall seeing a zipper, can't it be unzipped and replaced with another one?
Old 08-18-2009 | 03:56 PM
RedY2KS2k's Avatar
There's more to it than that.
Old 08-19-2009 | 05:43 PM
Emil St-Hilaire's Avatar
Go buy Plastix,chez Canadian Tire,et un peu d'Elbow grease,et elle sera comme neuve...
Old 08-20-2009 | 12:57 PM
s.french's Avatar
J'ai commander l'autre stuff sur ebay, je vais attendre que cela arrive et si sa marche pas, je vais esseyer les 2 autres produits =) Merci !
Old 08-20-2009 | 02:23 PM
thetz99's Avatar
If you have a porter cable, the plastic clears up nicely with menzerna ip/yellow pad followed by a lighter cut. A machine is always an easier alternative to hand rubbing.
Always tape around the soft top. Getting to the inside window is easier if you take the passenger seat out...4 quick bolts and it's gone, likely why it's easy to steal.
Quick Reply: Rear ''Plastic'' window 00 s2k
