Remove water stains from wheel
Old Aug 7, 2012 | 03:25 PM
spectacle's Avatar
Default Remove water stains from wheel
Not sure how this happened, but somehow I got water stains on one of my Volk wheels that I can't get out. None of my other wheels have this problem. I tried turtle wax wheel polish, but that didn't work. Any ideas?
Sent from my iPhone 4 using Tapatalk
Old Aug 7, 2012 | 04:59 PM
SiiK203's Avatar
If those are hard water spots try vinegar and water. Probably like a 50/50 mixture.
Old Aug 7, 2012 | 09:08 PM
ThatSlowKid's Avatar
Im 90% sure that it has clear coat on the polished part so I would recommend using some clay bar first and see if anything come off. It should work pretty good. If it doesn't work then use some rubbing compound, the more easy ones to buy are the ScratchX etc from Walmart or if you have any Meguiars 105,205 etc that works even better. It should take it off pretty easily.
Old Aug 10, 2012 | 06:53 AM
spectacle's Avatar
I will try the clay bar first, then the 50/50 mx of vinegar and water...thanks guys. Any other ideas?
Old May 7, 2014 | 07:18 AM
spectacle's Avatar
From the dead...
I just got around to trying to fix the aforementioned issue. I've been using Mothers Mag & Aluminum Polish and after about 2.5 hours of elbow grease I got most of it off. I'm debating on trying out the mini Powerball but I'm concerned about getting the polish on the painted areas. Has anyone attempted anything like this before?
Old May 7, 2014 | 04:20 PM
spectacle's Avatar
For future reference, the stuff on my wheels was oxidation. When you remove it with aluminum polish, it comes off black. Look how much came off of one just one wheel:
Sent from my iPad Mini using Tapatalk
Old May 7, 2014 | 06:48 PM
Vanishing Point's Avatar
Now you need to apply a sealant to keep the oxidation in check and help keep them clean.
Old May 7, 2014 | 08:44 PM
spectacle's Avatar
Any recommendations?
na2king
Jun 9, 2018 06:51 AM
ian05s2k
Sep 6, 2011 09:46 AM
shotiable
Jul 21, 2008 03:19 PM
s2krazy01
Mar 26, 2007 05:38 PM
importkid
Jul 26, 2006 07:08 PM
