Removing raggtop protectant
Old Oct 22, 2009 | 03:56 AM
//steve\\'s Avatar
Default Removing raggtop protectant
Typically when I use raggtop protectant I just spray it on in a few places and then grab a microfiber towel to really get it worked in and spread out evenly. This has been fine every other time I've done it but this last time I did it you can still see the spots where I sprayed first. When you get in the light right it looks terrible. I tend to use this method b/c it makes it easy to apply without making a mess of paint and windows as I usually do it after I've washed my car and let the top dry out.
Is there anything I can use to get the protectant off so that I can reapply properly. This only happened to half the top, on the other side I decided I'd spray my microfiber first and then work it into the top.
Thanks!
Old Oct 22, 2009 | 04:57 AM
zeroptzero's Avatar
I've got the raggtop cleaner, might want to try that and then re-apply the raggtop protectant. I would think the cleaner will remove some of the protectant residue.
Old Oct 22, 2009 | 07:22 AM
krshultz's Avatar
I'd just reapply over what you already have. Removing what's already on there seems like a waste of product to me.
Old Oct 22, 2009 | 12:55 PM
Grasshopper123's Avatar
I put raggtopp protectant a couple of months ago. I didn't notice that some droplets got on the paint. I have washed two times with Dawn and clay barred the car. These droplets haven't come off yet.
What is the best way to get these off before I proceed with the Zaino products?
Thanks very much for your help!
Old Oct 22, 2009 | 02:26 PM
slanguage's Avatar
Old Oct 22, 2009 | 02:27 PM
slanguage's Avatar
try a paint cleaner. or go to walmart and get some prep-all. follow the directions on the can. then apply fresh wax to that area.
Old Oct 23, 2009 | 06:28 AM
[QUOTE=slanguage,Oct 22 2009, 04:27 PM]try a paint cleaner.
Old Oct 23, 2009 | 07:54 PM
krshultz's Avatar
Uhh...you've got me stumped. I've never heard of such a thing.
Are you positive it's Raggtopp? Perhaps it's something else, and it's just a coincidence that you spotted it right around the same time you used the Raggtopp?
Old Oct 24, 2009 | 08:52 PM
I noticed the droplets a day or so after I applied the Raggtopp protectant. It was just obvious that's what it was, the reason being that the droplets were nowhere else except for around the edges of the top.
Now, I have used this product in the past, and it may be the wax job was holding up pretty well. Now, it needs a wax very badly, and perhaps now it's become a problem because of that.
So, I don't know why it did that.
Old Oct 24, 2009 | 11:47 PM
Luckyaze's Avatar
Foam pad work best imo...
