Removing sun block from windows
Do not use Acetone on Plastic. It will depend on the type of plastic, but I would rather be cautious if I were you.
As far as the GooGone is concerned- it will leave minor scratches on plastic along with a white surface residue that is produced. The white residue will not just wipe off.
Have you tried using distilled water and a mild detergent?
Test any solvent on a inconspicuous part of trim before you apply it all over.
WSB - try "JerseyGirl's Famous Window Cleaning Solution"!
Mix about 2 cups hot water with 1/4 cup each of white vinegar & ammonia. Use two rags (or paper towels) - one to wipe the solution on the windscreen and then the other to wipe it off. This will work well on windows, windshields, etc. No streaks!
Good luck w/ it!
Good luck w/ it!
if the above doesnt work... or if you want another idea:
try a glass polish such as autoglym:
http://www.autopia-carcare.com/ag-4325.html
btw, to prevent this in the future, spray your sunblock product on a rag away from the car and then rub it onto the area that you are protecting (dont spray it in the car).
