Retarded winshield
I washed and cleaned my car today including the winshield so i had it in the garage and it looked good and clean no streaks but then i'm drivign tonight anfd then bag it looks like its all foged up and smuged and just horible i went home and took some windex to it and it seemed like it worked. but i was wondering this hapen to any of you guys and what can i do to avoid it next time
did you wash both inside and out?
a detailers trick to help you figure out whether the glass is dirty on the inside or out:
wash the inside top to bottom and outside side to side.
then when you see dirty glass, you will know whether its outside or inside!
Never had a problem with a product for cleaning, only the media w/ which it's applied. Try Newspaper (no, I'm not kidding), the black and white pages seem to work better than the colored ones.
Also, I have found in the past it's much harder to get the windows truly clean in the garage, have to clean them outside to see that you got everything.
Travis
Travis
A fabric softener sheet will happily take bugs off the front of your car, I don't see it being helpful on a rag you use to clean windows (and no, you should be using fabric softener on your car cleaning rags anyway).
Nope, never get ink on the glass, be careful if you have a light colored interior not to wipe off excess spray on the door panels as it will come off there.
No method out of the ordinary, use the plain regular daily newspaper, spray light mist of whatever cleaner (I have used everything from a VERY diluted dishsoap in a spray bottle of water to any one of the Automotive window cleaners) slightly wad up the paper and wipe off the cleaner. After about 2 windows finish wadding up the paper and start on another one.
I swear in 10 years of trying stuff while detailing customer cars to another 5 or 6 of just my own this is the absolute best method for getting crystal clear, non-streaked windows every time. I assume the ink has something to do with the results and obviously there is no lint to contend with.
