S2000 rock chips
Originally Posted by hkspwrsche,Jan 9 2007, 12:04 PM
Why do these cars chip so easily!.. Got a divet in the window
guess your gonna need this link (the whole thread) for the paint!
https://www.s2ki.com/forums/index.php?act=S...=0#entry4696450
dont recall a glass thread... but for glass its usually a polish job (use glass polish with the pc), and if the chip is too deep polish can help but wont remove it. there are resin fillers, but they are not easy to use (last time i tried anyway).
Originally Posted by shotiable,Jan 9 2007, 09:18 PM
hey wanabe, do you think that method works for fixing key marks too? its the same concept as the rock chips... but they're just longer in form...
Originally Posted by wanabe,Jan 9 2007, 12:42 PM
paint is pretty thin...
Still, that's an awesome thread. It really shows the power of the PC and the proper application.
Originally Posted by wanabe,Jan 10 2007, 09:10 AM
it can work... i am not a paint expert (i assume that you mean in the paint)- let me see if i can get someone who might know to respond to this-
If it's just a surface scuff on the clearcoat (can't catch a fingernail on it), I would just give it a multi pass PC/sfx1 yellow pad/menzerna IP.
If you actually see metal, like in most paintchip hits, using a paintpen, waiting five-ten hours, then use clay to level would/does work. Then you just use the PC to blend.
If it is in deep cut, your option is again going to a paintpen, then clay level. Notice I am recommending clay over sandpaper. The trick is you don't want the paint to harden to the point the clay is ineffective...which is normally 5-10 hours. Once it hardens up, you have to go to the wetsanding method. Remember to turn the clay twice as often as normal as the paint trapped in it will gouge the finish.
thetz99, i dont believe i saw metal. so paintpen and clay to level out the paint it is. i'm assuming i use the clay the same way as normal (QD lube+ clay)
ooo i'm excited! i hate wet sanding! lol!! i also hate clearcoating stuff!
Originally Posted by thetz99,Jan 10 2007, 10:47 AM
Luckily I haven't had my S keyed. I have a Silverstone Accord that suffered a keying though and I had mixed results on using a paint pen on it...mostly because silverstone is tough to matchup right.
Oh well, I don't have too many chips that won't go away when I get a new bumper anyway. But there are a handful on the hood that I will probably tackle. I really would like to not have to buy a new hood.
Any tips on trying to tackle the silverstone? Perhaps the a way to apply it? And will different combinations of pads/polishs have a different effect on the paint?
= rock chips
= pay
