scratches
Old Jul 31, 2005 | 10:45 AM
StkS2000's Avatar
Default scratches
I made the mistake of taking my car to a hand carwash a few weeks ago. I made the wrong assumption that a hand carwash would be better than taking it to a car wash myself since I was limited on time. Well, as it turns out, I think they were using dirty towels/sponges, because I ended up with scratches on the hood and trunk, and a little bit on the sides. The scratches are not deep (not through clear coat or anything like that), just a little deeper than typical swirl marks and such. My question is, what is a good product/process to get the scratches out? I have a buffer, so I'm assuming I'll need that, I'm just not sure what to use since I've never had to deal with this before! Thanks!
By the way, I have a few zymol products, and they didn't do a thing to remove or hide the scratches.
Old Jul 31, 2005 | 11:35 AM
wanabe's Avatar
polishing will be your cure- i will find a good article for you and post it
here is one:
(i think that you might be able to skip the compounding step based on what you posted):
http://properautocare.com/usporcabpol.html
and another good one:
http://www.bettercarcare.com/articles.php?articleId=17
the key to any polish is to really work the product- and to end up working front to back (never in circles)- i prefer to use a machine (porter cable) for this job- to do it right by hand (which i will do on small jobs) takes a lot of work.
another tip is use the least aggressive polish that will get the job done... if your scratches are light, a swirl remover might get them...
finally, since i see that you have a black car- this is the swirl remover that i like:
http://properautocare.com/3mperswirmar.html
Old Aug 1, 2005 | 09:23 AM
StkS2000's Avatar
very informative links... thanks for the help! Looks like I'll be buying some new tools!
Old Aug 11, 2005 | 10:07 AM
s2000amuse's Avatar
So guys....the verdict is that the Zymol won't help to remove any swirl then?
Which is the best and safest swirl remover? Would 3M be it then?
So a coat of 3M swirl remover and then another coat of Zymol will do the job then?
aLcm
Mar 9, 2008 08:17 PM
Emil St-Hilaire
Sep 13, 2005 06:36 PM
lstlude
Aug 8, 2005 02:39 PM
dierk
Aug 18, 2002 08:57 PM
reds2
Aug 3, 2002 01:28 PM
