Which Sonus Clay?
Is the gray sonus clay too aggressive for use on a berlina black S? Would the green be sufficient to remove any left over road crap that is stuck on the paint (my car is a DD)?
can you i.d. the road crap??
if its tar, i wouldnt clay it- some guys do... but tar can contain sand or other grit, which turns clay into sandpaper!! so if you have tar, be very careful with clay
Originally Posted by dmw16' date='Mar 15 2007, 01:11 PM
I can't really ID it. It isn't tar. It's just little bits of stuff. The paint just feels rough. It isn't really anything id-able.
when i want to try a new clay, i pull off a piece and do the lower parts of the car first (lower rear)- then inspect... if it passes, then go for it. if any doubt forget it. and the little piece is trashed. if its a go, then i do more lower surfaces with that piece then trash.
i never experiment on the top surfaces-
the gray clay should be fine normally on black- sonus makes a very fine clay... is it green (cant remember right now)? that works really well if you are at all concerned.
wow you are fast! i was editing my post when you posted-
