Thoughts? (PICS)
Old Jun 26, 2011 | 04:07 AM
Alphamale's Avatar
Default Thoughts? (PICS)
Noticed this while waxing. The paint is just gone. Nothing scraped it off. The edges are perfectly smooth. Better than sanded smooth. There is also an area where the paint hasn't completely gone, as if the paint is just melting away. The odd thing is it still feels like there is clear there. Unlike the chips near by, there are no jagged edges, you couldn't locate the area by feel alone. The bare part feels just like the painted area. You can't catch a fingernail. Any idea how this could have happened?
Old Jun 26, 2011 | 06:51 AM
CarbonCrew's Avatar
Body lines and creases will always have the least amount of paint. That spot is what it looks like when someone has removed the clear and base during a polishing process.
Old Jun 26, 2011 | 08:21 AM
detailersdomain's Avatar
Former Sponsor
that looks like something burned thru the paint did you use a machine or have it detailed somewhere?
Old Jun 26, 2011 | 12:04 PM
zeroptzero's Avatar
What's the history of the vehicle ?, looks like a bad wet sanding job or someone used an improper polishing machine / materials /procedure.
Alphamale's Avatar
Unfathomable.
I did do some work on the hood, orange pad/SIP. All I did to the entire rest of the car was MicroPolish and blue pad. I wasn't even trying to work this area, just polish a bit since I'd washed with soap to remove wax. This is a Flex machine, blue detailers domain pad and MicroPolish. Very little time or pressure. This isn't my first rodeo either. How in the world did I manage that? The fender and trunk creases get much more "work" than that spot, they're great.
Old Jun 26, 2011 | 12:07 PM
Alphamale's Avatar
I've had the vehicle since 7500 miles. 70k now. All detail work has been done by me, flawlessly, for years. I could understand after a number of polish jobs the hard worked areas losing paint in this manner, but, I've never worked that area very hard.
Old Jun 26, 2011 | 01:51 PM
Honda007's Avatar
If it is as you say(can't really feel it), then it was burnt through as others have said. Unlikely, but perhaps that area had a thin base coat from factory?
Old Jun 26, 2011 | 02:30 PM
Alphamale's Avatar
So I'm looking at painting. Does anyone know how bad the J's type fenders are for increasing the amount chipping done by road debris? So much of the tire is exposed. If I'm going to have paint, I may replace the fenders, just no if it's going to cause more damage to the rest of the car.
Old Jun 29, 2011 | 05:04 AM
S2Kvondeutschland's Avatar
You could put some 3m clear bra on the fender behind the tire.
Old Jul 1, 2011 | 09:39 AM
Carbon Blue's Avatar
definitely looks like paint burn, edges such as those are very susceptible to burn. It was probably just a culmination of past polishing that all it took was a quick pass. Honda paint is very soft.
silvers2knewbie
Sep 23, 2010 11:18 AM
a_zepeda926
May 10, 2008 01:50 PM
Surreal_S2K
Nov 18, 2005 04:48 PM
VTEC_Junkie
Oct 28, 2003 10:31 PM
Alz2002
Jan 26, 2002 07:06 AM
