uh oh........engine clean....CLEANED!
Old May 25, 2008 | 09:39 PM
  #21
NFRs2000NYC's Avatar
Here is the OP's quote from the first post....
So off I go, spraying like mad in all areas with a warm engine. 5 minutes later, i rinse down with the engine running - hey presto, the valve cover looks amazing, the oil starts to wash away, and Im grinning.......
Big no no on all accounts.
Old May 27, 2008 | 04:12 AM
  #22
dennisp's Avatar
sorry, mistyped the explanation in a rush at work. It wasn't running. I rinsed down the engine with the engine off, and then ran it to dry it out quicker.
I think thats ok with what i researched as long as there are no wet connectors or alternator right?
Old May 27, 2008 | 04:32 AM
  #23
That's fine. As long as it's not running, you are fine. However, never spray a hot motor, even if it's off.
Old May 27, 2008 | 06:31 AM
  #24
mattfeet's Avatar
NFR- If you dont mind me asking, whats the real harm in running on a warm/running engine bay? I figure its something logical, and I never do it, but just am curious as to the reasoning. Thanks!
-Matt
Old May 28, 2008 | 03:28 AM
  #25
hue's Avatar
hue
wow that's pretty damn clean compared to the before pics, looks way much better
Old May 28, 2008 | 04:23 AM
  #26
-Matt
Stress on metal seals and all metal components. Metal doesn't like to cool quickly. Spraying hot headers can cause them to crack. Cast aluminum also cracks with huge temperature swings. It's not worth the risk, and sort of pointless, as the water will quickly evaporate, not letting you actually clean anything. The proper way to clean a motor is to spray it with cleaner, and let it sit for a minute of two before you scrub and rinse. With a hot motor, it will just evaporate, leaving white deposits all over your motor bay.
Old May 28, 2008 | 06:20 AM
  #27
mattfeet's Avatar
Thanks for the info. I knew about how it would adversely effect cleaning but was just curious as to the physical harm of it.
_Matt
Old May 30, 2008 | 02:58 AM
  #28
dennisp's Avatar
I read in my many hours of trawling the W&W forum that some people like to have the engine running so that if it 'hiccups' when washing down, you know that you are spraying in a 'bad' area.
Personally, I think its fine just to hose down anywhere apart from directly on the alternator from what people have written as a whole.
Can someone suggest suitable cleaner for the J's catch can? Is metal polish fine to use? It seems like a stange alloy mix?
Old May 30, 2008 | 07:15 PM
  #29
DrunkNmunky's Avatar
^Its easy to cover the parts with a plastic bag. I think the parts to be covered are the Alternator, fuse boxes and battery.
Old Jun 20, 2008 | 01:46 AM
  #30
dennisp's Avatar
bump for an answer on the J's racing catch can....
