water in headlight
Old Sep 6, 2004 | 09:43 PM
VTECturbo04's Avatar
Default water in headlight
Everytime it rains or I wash my car the driver side headlight always gets fog in it. Anyone know what would be causing this and how I can fix it?? Thanks
Old Sep 7, 2004 | 12:59 PM
wanabe's Avatar
[QUOTE=VTECturbo04,Sep 6 2004, 09:43 PM] Everytime it rains or I wash my car the driver side headlight always gets fog in it.
Old Sep 12, 2004 | 08:50 AM
95civicturbo's Avatar
What can be used to re-seal the headlights? I'm having the same problem.
Old Sep 12, 2004 | 02:20 PM
Stratocaster's Avatar
FYI
Our headlights are sealed, but wait; We have 4 large holes in them too. Those holes also have rubber seals. almost everyone forgets about them.
If you find that your headlights have moisture in them. You should do the following:
1. Remove the headlights from the car. (See www.ricks2k.com for diffuser installation instructions)
2. Dry the headlights out with a blow drier.
3. Bake them in the oven for 10min @ 225
4. Clamp them closed by hand. You will see the black seal expand against the clear lens.
5. Let them cool slowly. Quick swings in temp when they are open (no lights) can cause moisture to collect in the lights again.
6. Reinstall the headlight.
7. Using Shituz Grease (sp? you know the stuff for our tops) lube the rubber seals of each lamp.
Now everything should be better then new. Also this assumes that your headlights have never been opened to be cleared.
yuning83
Jun 21, 2009 09:30 AM
slvrAP1ftw
Oct 21, 2008 04:02 PM
qbmurderer13
Dec 26, 2007 04:41 AM
Formula
Dec 5, 2005 08:37 AM
highrev
Aug 27, 2003 11:55 AM
