what order to use?
Old Dec 19, 2002 | 05:29 PM
lovak6's Avatar
Default what order to use?
i need to get the swirls and microscratches out of my clearcoat. i do have an orbital buffer. i use zymol auto bathe to wash my car. now i need to know what to use first, 3m swirl remover or zymol hd cleanse?. then i have the zymol japon wax to seal it. i also have 303 protectant for my conv. top.
Old Dec 23, 2002 | 08:06 PM
wanabe's Avatar
i have used zymol bathe too... great sheeting action!
i would wash the car, then 3m swirl remove-
then wax/ or synthetic finish-
and buff to a newer than new car shine! (make sure that you use the proper pads on the orbital for each step of the process)
Old Dec 23, 2002 | 10:00 PM
mntony's Avatar
wanabe - does the 3M swirl remover leave anything wax-like on the surface? I.e. can you zaino right after using it?
Tony
Old Dec 24, 2002 | 08:10 AM
wanabe's Avatar
the 3m leaves nothing... it is a mild grit polish, so it will "eat" a slight amount of clear coat (as do all polishes). as i understand it, the grit works best as it breaks down while you are applying it. i have used it on my daughters car- great results with the p.c.
after applying and removing, i did remove by p.c.- but went over the entire car with a micro fiber towel by hand before applying the final finish (we used finish first on her car). but nothing is left on the surface (nothing at all!!!)
yes, you can zaino right after removing...
probably z1 then z2.
Old Dec 25, 2002 | 06:13 AM
mntony's Avatar
OK - thanks!
Old Dec 26, 2002 | 07:09 PM
lovak6's Avatar
thanks man, I did it today. I cleaned, then 3m, then hd cleanse (by the way this stuff works wonders), then I sealed everything with the japon wax. car looks immaculate!!
Sanguine
Jan 4, 2008 12:45 PM
slanguage
Oct 25, 2007 01:51 PM
Jaeden09
Jul 22, 2007 07:26 PM
DVSwetwilly
Jul 30, 2004 08:10 AM
TunedS2000
May 7, 2004 06:14 PM
