white FOAM
Pressure washer with foam cannon. electric PW will work also.
Not all soaps will work with the cannon.
Best soaps for Cannon are:
CG CWG
DG 901
DP Extreme Foam
I also own 2 foam guns, they do not even come close to foaming the same as the foam cannon. I use them only when Im in a rush.
CG CWG
DG 901
DP Extreme Foam
CG CWG
DG 901
DP Extreme Foam
CG CWG
DG 901
DP Extreme Foam
got more details?
he asked where you got yours, for example
The guy who I bought it from is kinda flaky and have screwed a couple of people out of their guns so I would not recommend him. They are still complaints about him and his Paypal account is frozen.
Another vendor in the UK sells these. They are about $150 just for the attachment not including the hose or the pressure washer.
I will try to dig up the site
This may be a dumb question, but do you rinse off the foam and then start using the mitt and 2 bucket method to finish cleaing? Or do you just grab the mitt and start going to town using the foam that has been sitting on the car.
I soak the entire car with deionized water, then I pressure wash the hard spots. Then spray the foam. Let sit, pressure wash it off, spray foam again.
I then use a sea foam or mitt depending on the condition of the car to wash the foam off with a rinse bucket.
I no longer use a 2 bucket method.
