Will claying remove wax....or
Old Jun 12, 2007 | 03:14 PM
slanguage's Avatar
Default Will claying remove wax....or
If I wanted to remove all the wax before washing and applying new wax, will claying do it? If not what will, and what is the easiest way? Also, is it a good idea to remove old wax before applying fresh wax? TIA
Old Jun 12, 2007 | 03:51 PM
jimmij's Avatar
claying will remove the old wax.
Old Jun 12, 2007 | 05:48 PM
wanabe's Avatar
and so will polishing...
(and so will dawn, but i wouldnt dawn a car except for its first protection)
Old Jun 12, 2007 | 06:28 PM
s98d7fs's Avatar
Probably the easiest and most effective way to do it would be a Isopropyl Alcohol wipe-down after washing the car.
Depending on the clay's abrasive level, claying might remove some of your wax. Sometime soon I'm going to try using the Sonus Green Clay (light abrasive) with lots of QD to keep it sliding on top of the sealant/wax, but removing the stuck on crud. Anyway, If I could pull that off, it'd save me a bunch of time... Having to reapply AIO, SG, and S100 after a clay just to get the paint smooth is timeconsuming and a pain.
Old Jun 12, 2007 | 08:54 PM
diabolus2k's Avatar
I use a mix of 50% distilled water and 50% IPA... works great for removing wax and polish residue
Old Jun 12, 2007 | 09:00 PM
animeS2K's Avatar
50/50 here.
or if I really want to strip EVERYTHING off, I'll use the 3M Adhesive Remover while wearing a VOC mask and gloves.
Old Jun 13, 2007 | 01:29 AM
FMINUS's Avatar
A precleaner lotion would help to prep the paint
Old Jun 13, 2007 | 03:31 AM
slanguage's Avatar
Thanks for all the replies guys
Old Jun 13, 2007 | 08:01 AM
GTScott's Avatar
I always use a 50/50 after polishing to remove any oils or such. You use it ina fashion similar to a spray detailer. IMO, it leaves the surface ultra clean and ready for the sealant to bond properly.
Old Jun 15, 2007 | 12:36 PM
dolebludger's Avatar
I've found that clay bar may remove the very top layer of the wax, exposing cleaner wax below for further waxing and such. But if you are wanting to remove ALL the wax, you are going to be rubbing quite a while with that clay bar.
slanguage
Jul 14, 2008 08:59 PM
Sanguine
Jan 4, 2008 12:45 PM
LegendaryHarry
Aug 13, 2007 08:04 AM
notyourfriend
Feb 15, 2007 07:19 AM
Sickdayracing
May 3, 2005 11:47 PM
