San Diego S2000 Owners San Diego and Imperial County S2000 Owners Community meets, events and discussions.
acceleration
Old Jan 21, 2012 | 01:20 PM
bradskee's Avatar
Default acceleration
For all you NHRA fans out there A Definition of Acceleration
One Top Fuel dragster 500 cubic inch Hemi engine makes more horsepower than the first 4 rows of NASCARS at the Daytona 500.
Under full throttle, a dragster engine consumes 1-1/2 gallons of nitro methane per second; a fully loaded 747 consumes jet fuel at the same rate with 25% less energy being produced.
A stock Dodge Hemi V8 engine cannot produce enough power to drive the dragster's supercharger.
With 3,000 CFM of air being rammed in by the supercharger on overdrive, the fuel mixture is compressed into a near-solid form before ignition. Cylinders run on the verge of hydraulic lock at full throttle.
At the stoichiometric (stoichiometry: methodology and technology by which quantities of reactants and products in chemical reactions are determined) 1.7:1 air/fuel mixture for nitro methane, the flame front temperature measures 7,050 degrees F.
Nitro methane burns yellow. The spectacular white flame seen above the stacks at night is raw burning hydrogen, dissociated from atmospheric water vapor by the searing exhaust gases.
Dual magnetos supply 44 amps to each spark plug. This is the output of an arc welder in each cylinder.
Spark plug electrodes are totally consumed during a pass. After halfway, the engine is dieseling from compression, plus the glow of exhaust valves at 1,400 degrees F. The engine can only be shut down by cutting the fuel flow.
If spark momentarily fails early in the run, unburned nitro builds up in the affected cylinders and then explodes with sufficient force to blow cylinder heads off the block in pieces or split the block in half.
In order to exceed 300 mph in 4.5 seconds, dragsters must accelerate an average of over 4G's. In order to reach 200 mph (well before half-track), the launch acceleration approaches 8G's.
Dragsters reach over 300 miles per hour before you have completed reading this sentence.
Top Fuel engines turn approximately 540 revolutions from light to light!
Including the burnout, the engine must only survive 900 revolutions under load.
The redline is actually quite high at 9,500 rpm.
Assuming all the equipment is paid off, the crew worked for free, and for once NOTHING BLOWS UP, each run costs an estimated $1,000.00 per second.
The current Top Fuel dragster elapsed time record is 4.428 seconds for the quarter mile (06, Tony Schumacher). The top speed record is 336.15 mph. (533 km/h) as measured over the last 66' of the run (05).
Putting all of this into perspective:
You are driving the average $140,000 Lingenfelter "twin-turbo" powered Corvette Z06. Over a mile up the road, a Top Fuel dragster is staged and ready to launch down a quarter mile strip as you pass. You have the advantage of a flying start. You run the Vette hard up through the gears and blast across the starting line and past the dragster at an honest 200 mph. The 'tree' goes green for both of you at that moment.
The dragster launches and starts after you. You keep your foot down hard, but you hear an incredibly brutal whine that sears your eardrums and within 3 seconds, the dragster catches and passes you. He beats you to the finish line, a quarter mile away from where you just passed him. Think about it, from a standing start, the dragster had spotted you 200 mph and not only caught, but nearly blasted you off the road when he passed you within a mere 1,320 foot long race course.
Old Jan 21, 2012 | 01:38 PM
SDgoods's Avatar
amazing
Old Jan 21, 2012 | 01:40 PM
ASIXMRSE's Avatar
bad ass
Old Jan 21, 2012 | 03:13 PM
Carbon Blue's Avatar
good read, the formula 1 article is also a jaw dropping article.
Old Jan 21, 2012 | 03:38 PM
bigjeff808's Avatar
Dude awesome read thanks for sharing.
Sent from my iPhone using Tapatalk
Old Jan 21, 2012 | 04:35 PM
SDMORROW's Avatar
WOW
Old Jan 21, 2012 | 09:39 PM
S-ni-sen's Avatar
Yeah the F1 stuff is crazy, they run these cars right on the edge of reliability/sanity.
With all this power and violent force coming out of the engine how is it transferred to the ground? And what about grip?
Old Jan 21, 2012 | 10:55 PM
bdo's Avatar
bdo
Link to F1 article?
Old Jan 21, 2012 | 10:57 PM
bigjeff808's Avatar
Originally Posted by bdo
Link to F1 article?
please!
Old Jan 26, 2012 | 04:45 PM
danhinton's Avatar
WOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO OOOOOOOOOOOOW
I feel like I drive a f@#king power wheel now.. thanks...
Stil awesome to read though.. Most pilots dont pull 8g's, thats the only thing I wonder on how true it is, cuz if you really pull 8g's thats like black out state, honestly... Not doubting the write up, but these dudes would make amzing pilots if they do 8g's with no pressure suits!!
could you imagine what it would be like to take just ONE ride with one of these guys....
