Engine light on? WTF!
Originally Posted by Rasetsu99,Nov 26 2008, 01:14 PM
Did you recently fill up your tank? If you don't tighten your gas cap enough, it will trip the check engine light.
Someone is not reading this tread
Paul, it should e a easy fix. First I was going to just check to see if everthing is ok and clean it like you side.
Is it ok though to purchase a aftermarket replacement if I need to? The OEM are pretty pricy.
Originally Posted by latinochino,Nov 26 2008, 03:41 PM
Well from my research they have the plug on the other end so no wire cutting or splicing.
So how much you looking for the used one? It is the rear one.
hey latinochino I don't know how much you have check for the universal sensors but I found this one in Kragen.com since I work at kragen I might be able to give you a deal PM if you need anything.
this one is the downstream
http://shop.oreillyauto.com/productdetail....ype=291&PTSet=A
thank you.
I will get a aftermarket replacment for now to see how it turns out. I really should get a OEM replacement but they are to much and this is the worst time to spend money since christmas is coming and all.
