San Diego S2000 Owners San Diego and Imperial County S2000 Owners Community meets, events and discussions.
need some help
Old May 8, 2011 | 11:01 PM
xxGPWS2Kxx's Avatar
Default need some help
Ok quick rundown. MY06 w/ ~93K. only mods are mishu. rad., invidia 70mm TP and Q300 exhuast.Main't
done like clockwork. came home from the track yesterday fine w/ no problem.
Woke up this a m and degreased and deatailed the engine bay. started it up after the recommended sit time...no problem.
several hrs later went to go grab a biteand check engine like started flashing. went home and saw code for misfire #3. switch plug to #1 cyl. then got misfire #1 and white smoke from exhaust.
Replaced all for plugs ( w/ oem ) inspected coils and no sign of arking. Still getting code for misfire #1 cyl. the ticking I hear doesnt sound like its coming from the block. Used my stethascope to listen on each cylinder. no more white smoke from exhaust but really rough idle and flashing check engine light still.
Going to do compression/leak test tomorrow. I've never had any issues before. Just had valve adjustment done ~ 6 months ago. Get it done once a year. Advice??
http://www.youtube.com/watch?v=kfC6m...er_profilepage
Old May 8, 2011 | 11:05 PM
TurboViper's Avatar
sounds like you got water in one of the coil pack connectors or one of the injectors, water runs down inside the connector to the injector and sits in the connector. It will short the signal out going to it and cause it to not open.. Let it dry overnight and it should be fine!
Old May 9, 2011 | 06:33 AM
xxGPWS2Kxx's Avatar
well woke up this morning and drove it around the block and still running rough and check engine
started flashing again
Old May 9, 2011 | 06:52 AM
JDMQuip's Avatar
Hey hey hey, sounds like my problem. Minus the white smoke and flashing CEL. Mine decided to be solid.
Wish I could help buddy buttttt.....
Old May 9, 2011 | 07:17 AM
BSeriouS's Avatar
Sounds like you need to hit up RSXbuilt for that motor!
Old May 9, 2011 | 08:46 AM
bdo's Avatar
bdo
What Gavin said, except try taking it apart and blow the connectors out really good with air??
Edit: Why did my post come out in bold?
Old May 9, 2011 | 01:35 PM
bradskee's Avatar
so confused
Old May 9, 2011 | 02:29 PM
TurboViper's Avatar
Agreed, try blowing all the connectors out with air, you got watter somewhere.. your motor wont die just like that
Bserious has an open ended html tag in is sig, I already sent him a PM about it.
Old May 9, 2011 | 02:30 PM
xxGPWS2Kxx's Avatar
Okay just finished the compression test and this is what I got after and average of 4 runs.
1.250
2.250
3.247.5
4.241.25
looks good to me...
does anyone have some used(functional) coils that I can test out, borrow. Dont wanna have to spend
400 bucks on a what ifs ( rather spend it on my new seat ) call me @ 760 458 3511
Also noticed that my gromets and seal are pretty torn up. replacing that today aswell, but dont wanna
replace them if im going to have to take them off again to test something else out....help...
Old May 9, 2011 | 02:50 PM
xxGPWS2Kxx's Avatar
the only other thing I can think of was that water got in somewhere when I was degreasing the motor dont see where or how. cover alternator, battery and pretty much any exposed wires
I could see either w/ a plastic bag or tape. could it seep through the sparkplug cover??
