San Diego S2000 Owners San Diego and Imperial County S2000 Owners Community meets, events and discussions.
Reputable S2000 Shop
Old Aug 12, 2009 | 07:56 PM
MTS2POPPIN's Avatar
Default Reputable S2000 Shop
Hi guys,
I have been tring to sell my car but all of sudden there is a crazy noise coming from the rear of my car. I went to a shop and they said it was because it was lowered and I need axle spacers. The noise is hard to explain but only happens when the car is driven for awhile. It's like a whining screaching noise from my rear passenger side.
I need a shop that would be able to fix this I honestly don't believe it's because the car needs spacers.
I think it is either the rotor our the pads but the Mechanic said they where fine.
The noise does go away when I make a turn or accelerate it's weird....
So I was wondering if someone can refer me to a good honest shop.
Old Aug 12, 2009 | 08:26 PM
latinochino's Avatar
https://www.s2ki.com/forums/index.php?showtopic=715908
Read this link and see my comments and others here in SD.
Old Aug 12, 2009 | 08:33 PM
bradskee's Avatar
i would put money on its the bearing and hub. its a really involved job and you need a press. heres the parts youll need if it helps
Part #2 the rear wheel hub 42210-S2A-000
Part #36 the rear wheel bearing 44300-S47-008
Old Aug 12, 2009 | 10:07 PM
MTS2POPPIN's Avatar
thx for the advice guys does anyone know how much it would be aprox. to replace the bearing and hub? looking to fix it soon school is starting and I want to fix it before then.
Old Aug 13, 2009 | 12:26 AM
daygolove's Avatar
pm JasonSBAP1
he had the same problem
Old Aug 13, 2009 | 07:41 AM
ABCVTEC's Avatar
I had the same problem as well. It's most likely a wheel bearing.
Also something you can check before you go and spend money on a wheel bearing a hub is to have the axle nut retorqued. A loose axle nut can cause the problem too.
Old Aug 13, 2009 | 09:35 PM
MTS2POPPIN's Avatar
i'll pm him thx
B-Mo
Jun 18, 2014 06:02 PM
ForkYou
Nov 25, 2011 09:12 AM
jezzder
Apr 4, 2009 08:57 AM
adam_gipson
13
Aug 4, 2005 07:37 AM
TruRicer
Apr 29, 2004 08:56 AM
