spark plug TSB is now a recall
Old Aug 11, 2002 | 06:26 AM
Lightning's Avatar
the gaskets are on the spark plug. you don't change the gaskets on the plug to the new type of gasket, you change the plug itself. this helps the plug stay in there nice and tight, whereas the old plug had a tendency to work itself loose /sometimes/. mine is now done, and it feels, well, like i just put new plug in my car. this TSB/recall does NOT apply to aftermarket plugs. if you already changed 'em, what's the point in going back to stock?
Old Aug 11, 2002 | 03:49 PM
Txs2k's Avatar
I called my dealer about this, & they don't even have the replacement plugs in stock & said to call back in about a month! Must not be anything too urgent!
Old Aug 11, 2002 | 07:48 PM
Gloffer's Avatar
The title of my letter from Honda is: Product Update Campaign: S2000 Spark Plugs
I guess this is a new category now we have:
Recall
Technical Service Bulletin
Old Aug 11, 2002 | 09:27 PM
Lightning's Avatar
i can't believe that a dealer doesn't have 'em - mine /volunteered/ the TSB without me asking about it - they had the kits in stock!
Old Aug 12, 2002 | 07:42 AM
WhiteS2k's Avatar
I have not received any recall letter from AHM yet. But what about the other part of the "recall" from Europe (the so-called "4th cylinder" problem)? How come AHM did't say anything about that? Reference these previous postings:
https://www.s2ki.com/forums/showthread.php?...&threadid=67081
https://www.s2ki.com/forums/showthread.php?...?threadid=69568
The post by Ronald mentioned replacing "oilbolts" with 4-holes (instead of the original bolts with 2-holes). Anyone ever discuss this part of the problem with their American Honda service people? Just very curious.
Old Aug 12, 2002 | 08:06 AM
wanabe's Avatar
utah- seems strange that the new plugs are the same as the old except for the gasket-
i did note that a difference is the torque for installation (new plugs are torqued differently). i guess because of the different gasket?
maybe they replace the plugs in case the old ones were damaged by bad gaskets?
sure would be nice if honda would give us explanations!
Old Aug 12, 2002 | 10:05 AM
S2K Power's Avatar
So if we det aftermarket plugs what should we torque it to, 13 or 18?
Old Aug 12, 2002 | 10:16 AM
dlq04's Avatar
Since the S2k plugs have been bumped up to 18 from the original 13, I say to use at least 18. . . or higher if that's what the plug mfg recommends.
Old Aug 12, 2002 | 11:34 AM
Randy's Avatar
I agree, I'd torque to 18 w/any plugs.
BTW: Got my letter today...
My theory on "product update" is to avoid it looking like a recall from a PR perspective.
Now statistically Honda has fewer recalls--simply by defining them differently.
(Our planet is 100% crime-free. There are no laws.)
Randy
Old Aug 12, 2002 | 11:57 AM
Fed's Avatar
Fed
Copy of letter.
