Cruise not working
Old 06-25-2017, 12:42 PM
plizzat's Avatar
Default Cruise not working
The button wont light up. Already checked fuse 47. Has anyone had a module go bad? Thanks.
Old 06-25-2017, 03:07 PM
Bamafan's Avatar
It is almost always the white nipple under the pedal that breaks. It's a cheap fix.
Old 06-25-2017, 04:12 PM
plizzat's Avatar
Thanks, I'll look at that.
Old 06-25-2017, 04:17 PM
Chuck S's Avatar
Received 1,134 Likes on 997 Posts
It's the little plastic part on the clutch pedal that makes the cruise control think the clutch is depressed.
-- Chuck
Old 06-25-2017, 04:24 PM
panda25's Avatar
why does cruise control even exist in our cars??
Old 06-25-2017, 05:00 PM
HarryD's Avatar
Have you not driven this car on long trips, 100+ miles straight, out on the open road? Give it a shot sometime.
Old 06-25-2017, 08:24 PM
plizzat's Avatar
Under the gas pedal?
Old 06-26-2017, 04:00 AM
Chuck S's Avatar
Pretty sure it's under the clutch pedal. Not under-under but up top were the pivot is.
There's an electrical plunger up there that doesn't get depressed (or pressed?) when this part falls off and the cruise control thinks the clutch is depressed and kills cruise like it does if you change gears.
-- Chuck
Old 07-06-2017, 05:23 PM
plizzat's Avatar
That part falling off probably wouldn't cause the activation light to go out when pressed would it?
Old 07-07-2017, 03:28 AM
Chuck S's Avatar
Cruise control -- and air conditioning!, things those Brit roadsters of long ago never had-- are vital on long drives of (say) several hundred miles. Unless you want to be "that guy" whose highway speed is constantly varying and making the, admittedly few, guys behind you nuts.
Keep the spend constant while you're texting as well.
Set it for the speed limit and when your Valentine 1 goes off just lift off the gas pedal and you're all nice and legal.
-- Chuck
Quick Reply: Cruise not working
